Fireblade_rr
First off, yes the old DMF was replaced with the updated part# part.
So I have a very distinct rattle when coming to a stop.
I also have this same rattle when reversing. Put car into reverse give a little throttle input and I hear the rattle. It’s fairly loud and slows and gets a bit quieter when I come to a stop. When stopped still in R with break pedal pressed there is a slight rattle, shift into N and it kind of goes away then put into D and it gets a bit louder.
No rattle on start up or shut down.
Doesn’t sound like the rattle the failing DMF was making.
Trying to avoid going to the dealer as I’m out of standard warranty and all worked performed was under my extended warranty.
