Anyway to get UMI version without going to dealer?
hephaestus
GNWFL
2014 Jetta Sportwagon
Any way to get UMI software version without going to dealer?
My phone has massive issues connecting to my radio via bluetooth in my 2014 Sportwagen w/Nav. I found TSB 9115-02, which applies to all Bluetooth-equipped 2014 VW vehicles:
UMI Software Update for Various Bluetooth Concerns
The customer may complain of one or more of the following symptoms:
^ Voice Prompts stuck in Non-English Language
^ Poor Call Clarity on Receiving End
^ Various Bluetooth Connectivity & Paring issues
Technical Background
This procedure corrects the concerns listed above by updating the UMI to the latest software SW 0592.
Production Solution
UMI Software Update Initiated During Production.
Service
Software Update Procedure
Tip:
The UMI software level can be checked using the VAS Diagnostic tester. If the Software version number in AW 77 is at or above 0592, this work procedure does not apply.
I already know what the dealer is going to say when I call, "For $112.95 we can hook it up and see if that TSB applies to your vehicle." Is there any way I can check my UMI SW version without involving the dealer for now just to see if the TSB applies?
hephaestus
GNWFL
I figured it out. If you hold the setup button it will bring you to the internal into screens that show you the versions of everything and signal strengths. I need the update.
Are there other updates I should have them do while I'm paying to have this one done?
