check that, it is Engine Fault, Workshop...anyone experience this engine run-on before...it does eventually shut off. I have the VCDS and can send someone, anyone? the log file if they want to see it, thanks.
The biggest red wire with the nut on it as per instructions. This only just happened yesterday. Fogs have been in for a week and operating normally. The drivers side did not work.
Sheepish and red-faced I am and the emergency is over. So sorry to have bothered you all.
Over and out!
