TDIJohnny
I'm having a debate with someone about the right way to park the TDI. I believe neutral is the way to gono matter what. On level ground or a graded road/driveway. As long as the brake is on good and tight. This avoids accidental and probably damaging stalls after starting it back up if you don't realize it is in gear and let the clutch out.
The argument is that if left in first, it aids the P-Brake in holding the car in place if the brake is not fully engaged. I would think that could be harmful in some way to the gears (I'm no mechanical expert).
Is there a decided method to this or is it just driver preference?
