Well, not really. D#2 can be additive added, but it's still #2 due to the fact that it's a certain viscosity or thicker than #1. It has more btu, so more energy content. As mentioned, #2 is often blended with #1 to prevent gelling in winter and in extreme cold some (myself included, on a few occasions) have run straight #1. Talking -30F extreme cold. Truck stops and some fuel stations will have both for letting the driver/operator choose their blend ratio or add as required for the area they intend to travel to or thru........
So what i gather is this, Diesel #2 is Plain old Diesel fuel, used for Spring, Summer, Fall,
But Diesel #1 is Diesel 2 With ADDITIVES to prevent gelling in Cold weather. I just stopped at a truck stop that had both 1 & 2, and that is what the attendant told me.
Down in your area they DO have synthetic dieselDont use sythectic d2 till after its broke in.
NB = New Beetle.
And no, D1 is NOT simply treated D2. They are different fractions of the refining process. It's also NOT TRUE that D1 is simply kerosene. All 3 are distinct products that overlap. Heating fuel oil is also in this family . However - it is NOT usually down to ULSD standards either. Back in the old days - you could use home heating oil as fuel for your Diesel vehicle - provided you didn't get caught with the red-dyed fuel in your tank (which can lead to big fines).
There are places where it gets REALLY cold that you can find both D1 and D2 ULSD - D1 has the advantage of being more inherently gell -resistant.
