First thing in the morning when I start it the blue engine coolant light is on.
I forgot to mention that when you first start it the coolant temperature light stays on until the engine warms
I'm not familiar with a blue engine coolant light.
Can you look at this diagram and confirm it's the coolant light?
It is normally red, although I suppose your car could have some modification? If that is lit when you first turn on the car, but goes out when it's warmed up then it will mean one of several things but start with the simple first.
Coolant level is probably just a touch too low. When the car warms up and and coolant expands a bit then the level rises. Try adding a little bit. Also worth noting that the coolant in your car should be pink in color. If it's green (or worse yet brown) that means someone mixed in an improper type of coolant. The proper coolant for your car will be called 'G12', although you may see some called 'G12++'. It will typically need to be mixed 50/50 with distilled water.
However after running for a few minutes the car dies after it chokes a couple times. Then the glow plug light comes on flashing as well as the check engine light. Starts back up and drive down the road fine however you can feel a little bit of hesitation. Here are the codes that was pulled from AutoZone before I changed the alternator P1354, P 1562, P 1563. What do I do next? Thanks for all the replies prior to this post appreciate it now at least I'm back on the road
Those are all trouble codes monitoring the injection pump.
17970/P1562/005474 - Quantity Adjuster (N146): Upper Limit Reached
17971/P1563/005475 - Quantity Adjuster (N146): Lower Limit Reached
17762/P1354 - Modulating Piston Movement Sensor (G149): Electrical Malfunction
Could be a wiring problem to the pump, could be an adjustment issue, or the pump could be bad.
Best advice would be to try to find a trusted mechanic from the list in the TDI101 sticky to take a look at it. You don't want to start just throwing parts at those sorts of codes because it will get
expensive very fast.
So you definitely want to be sure that it's diagnosed correctly.
http://forums.tdiclub.com/showthread.php?t=130044
