RobbyP
Ive owned the swap for almost 4 years. Alittle less than a year ago I ran into an issue where a click would be heard from the engine but it would intermittently crank over. Ive replaced the battery cables, ignition switch, and have done all the diag to rule out the wiring. Have also used multiple starters intended for use in a 96 passat tdi (donor car). Have used an ebay starter, bosch, and valeo and the issue still persists. Im almost 100% certain that the starter gear is hitting the flywheel ring gear and binding. There is faint marks on the flywheel aswell.. Causing it to only start sometimes. Flywheel is from a Southbend clutch kit and is a G60 flywheel is was installed probably 10 months before this issue started so I can rule out any flywheel installation error. Is it worth trying a starter from a G60 corrado? The two vehicles share the same trans so they will bolt up.
