AnotherPerson
So when we got the car we found out that the high voltage fuse box was melted. Changed it, shortly after the fuse melted again. We than found out that both fans were on there way out. One was very hard to spin and the other started making bearing noise.
Changed the fans, replaced the box again. Fuse melted again.
Read about chinese fuses, replaced the fuse with a good quality one, no longer is the fuse melting but now on hot days the fans are cycling on and off when the AC is on causing it to get cold than warm up some, than the fans come back on.
Any ideas for me? AC isnt low and its blowing ice cubes while the fans stay on just when they kick off unless im moving a decent speed it warms up.
Thanks for putting up with all my questions. Im going down the line fixing stuff on the car as I can but this fan issue seems to be never ending.
