Golf Mk V GT 2.0 TDi Fuse Box
TDi4Tez
London
04 Golf 2.0 TDi
After quite some time Googling I eventually managed to get the layout for my fuse box, well a fuse box cos this layout is Mark 1V and I'm Mark V. There just is not one of those anywhere can anyone help. Its RHD (UK) 54 plate (Dec 04). I have found the fuse box (now there's a days work but thats another story), but there is no details anywhere as to which is what. My rear wiper and washer has gone and I don't know which fuse it is. Thanks.
hid3
Banned
Lithuania, Vilnius
Golf V 1.9 TDI-PD 105 HP
Wiper and washer is a poor design in Golf V. Mine was leaking water and everything under the panel was rusty there! Even FM amplifier which was attached to the trunk. If I were you, I'd remove the rear panel firstly and see what happens there. If you find much rust there then maybe a corroded contact is your problem. Remember, once it looses contact to wiper motor, both the motor and washer stops working. Also you can check with multimeter if it supplies voltage there.
