osesu96
Hi @oilhammer ,So check the charge air system, specifically the o-rings at the snap-fit connectors. Depending on which engine it is, I can give more specific hints.
So I got a P0101 yesterday. Car still ran well though had a small bobble around 1200 rpm but cleared up above that RPM and idles normally. I have curated a few things to look at such as the o-ring snap-fit connectors and I'm going to pull the valve cover to look at the cam.
As it relates to your comment above, I have a BEW engine, what would be the first hints you would recommend? Note: Car has the "Collar Mod".
Thank you in advance for the suggestions.
