Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old March 13th, 2018, 17:10   #16
wxman
TDI(s): Other Diesel
Originally Posted by bhtooefr View Post
Interesting - so 22.3% of the gasoline GHG emissions are from feedstock or fuel (well to tank), 20.8% of the diesel GHG emissions are from feedstock or fuel.
However, I do find it interesting how much lower the feedstock stage is for gasoline (E10 doesn't fully explain it), and how much higher the fuel stage is.
Can you explain?
According to the GREET user's manual, "Feedstock" (in the case of petroleum) is "Extraction of oil and its transportation to the refinery." Why would there be any difference between the two fuels in the case of E0 gasoline?
wxman is online now   Reply With Quote
Old March 13th, 2018, 17:38   #17
Tin Man
Tin Man's Avatar
Fuel Economy: 51/40/30 TDI PD, 42/37/32 535d, 52/46/42 XE 2.0d
I'm surprised by the higher total CO output of diesel. Guess I can't say diesel exhaust is as safe as I thought!
Thanks wxman!
'16 535d, '17 XE 2.0d, '04 NB TDI PD DSG
"We see things not as they are, but as we are."-- H. M. Tomlinson
"Once I make up my mind, I'm full of indecision."-- Oscar Levant
Tin Man is offline   Reply With Quote
Old March 13th, 2018, 17:51   #18
wxman
Thanks wxman!
Yeah, I'm not sure about that either, Tin Man.
The tailpipe CO emissions in the ICCT/WVU study that discovered the VW TDI defeat device in the first place showed very low emissions for all three of the diesel cars they tested - 0.1 g/mile or less.
I think ANL got the tailpipe emissions data from EPA, but I'm not sure why the default CO emissions are relatively so high.
Old March 13th, 2018, 20:11   #19
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Originally Posted by wxman View Post
Can you explain?
But the "feedstock" GHG emissions are significantly lower than diesel - more than 10% lower. (And 10% lower would assume zero emissions from ethanol, which, no.)
Which tells me that there's something going on - maybe they're having to crack other fractions of the barrel of oil, increasing emissions, to get diesel?
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is online now   Reply With Quote
Old March 13th, 2018, 22:08   #20
turbobrick240
turbobrick240's Avatar
Maybe because the refineries are getting more gallons of gasoline per barrel of crude than diesel fuel?
turbobrick240 is online now   Reply With Quote
Old March 14th, 2018, 08:13   #21
CraziFuzzy
I believe GREET considers the Carbon fixation of the ethanol crops in it's net CO2 feedstock numbers. So that 10% has a lot more than a 10% net effect.
CraziFuzzy is offline   Reply With Quote
Old March 14th, 2018, 10:03   #22
turbobrick240
I think the feedstock value difference is a combination of the ethanol factor and the higher yield of gasoline per barrel crude. Our refineries get twice as many gallons of gas as diesel from a given amount of crude oil.
I think it very unlikely that corn ethanol crops are fixing carbon into the soil. The best they could do really would be carbon neutral- also quite unlikely. Some forms of cellulosic ethanol could be close to carbon neutral though.
Old March 14th, 2018, 10:28   #23
CraziFuzzy
totally depends on what the non-sugar carbons are doing from the crops.
Old March 14th, 2018, 10:41   #24
turbobrick240
Even with the best no till practices (thanks Monsanto), I can't see corn ethanol crops building the soil. The cover crops planted between rotations perhaps. Hopefully there will be a shift to cellulosic ethanol soon.
Old March 14th, 2018, 11:04   #25
ToxicDoc
TDI(s): 2001 Jetta
I believe the jury is still out as to whether cellulosic ethanol is economically viable. Even on a very large scale the data isn't back. Unless they make some enzymatic breakthrough it seems marginal.
ToxicDoc is offline   Reply With Quote
Old March 14th, 2018, 11:17   #26
wxman
That is my understanding.
Old March 15th, 2018, 04:45   #27
CraziFuzzy
Carbon fixation is not just the storage of carbon in soil, it's the storage of it in any non-CO2 form. Even as much as using the non-digested solids as physical fillers represents a form of carbon fixation.
Old March 15th, 2018, 17:44   #28
turbobrick240
Yeah, I checked out the latest Argonne and USDA life cycle analyses for corn ethanol ghg emissions. It looks as though they are carbon crediting the domestic corn-ethanol production for land use change (mostly carbon sequestration in soils I think), and co products like distillers grain for animal feed & corn oil for biodiesel. Also something about domestic rice methane- not sure what that's about. It's worth mentioning that there is quite a lot of variation in different life cycle analyses over the past 10 years- especially in the land use change category.
Of course there are other environmental impacts from the fertilizer, herbicide, pesticide, and water use completely separate from the GHG emissions. I'm all for biofuels, I just don't think corn ethanol is all that great.
Old March 16th, 2018, 07:52   #29
kjclow
The amount of gasoline versus diesel will vary depending on the source of the crude oil. I think your "twice the gallons" generalization is grossly overstated.
kjclow is online now   Reply With Quote
Old March 16th, 2018, 08:34   #30
Tin Man
Tin Man's Avatar
I suspect I'm correct about this, but the US exports refined diesel and imports refined gasoline from Europe.
Gasoline traditionally is a waste product of diesel production, which if my econ 101 knowledge is correct, makes production of diesel the profit center and gasoline not so much. Therefore, gasoline is cheaper per gallon (keeping in mind higher taxes on diesel as well as various regulations on gasoline qualities) and is the secondary product. It would surprise me if refineries were not set up to bring more diesel and less gasoline. This explains the price differential but also makes gasoline production irrelevant to energy output. Diesel production drives our use of transportation crude oil, not gasoline. So to create less CO2, as well as other "pollutant" production (which arguably is better for diesel) improve the efficiency of everything, but concentrate on diesel.
TM
Paper on diesel vs. gasoline well to wheels CO2 emissions durundal TDI (Diesel) Emissions 7 February 28th, 2009 14:36
Ethanol emissions (I know it isn't diesel, but is emissions related!) thenewguy TDI (Diesel) Emissions 8 April 23rd, 2007 07:31
Energy balance ratio of gasoline, ethanol, diesel, and biodiesel Dorado TDI Fuel Economy 8 June 24th, 2002 11:08
CO2 emissions of diesel vs. gasoline and ethanol fuel production TDI (Diesel) Emissions 0 December 31st, 1969 17:00
Page generated in 0.13261 seconds with 13 queries
[Output: 129.17 Kb. compressed to 107.92 Kb. by saving 21.25 Kb. (16.45%)]
