coldfire
Car is an 02 beetle tdi.
Some background:
I was unable to shift into gears before we started. We had tried to bleed it and got nowhere, adjusted the linkage and nothing changed. The car moved forward with clutch pressed all the way to the floor. Swapped the slave, nothing changed. Bled some more and got nowhere.
So, I swapped out the transmission, the clutch, flywheel, pressure plate. The old flywheel was in bad shape, all the bolt holes were initially covered but we were able to move it freely.
Everything went back together smooth and we started it up only to find we have the exact same problem. We bled the clutch again, no bubbles came out.
I am at a loss, please help!
Drew
Some background:
Drew
