Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Non VW Group Diesels
Non VW Group Diesels This section is for discusion of Non VWGroup Diesels.
Old September 13th, 2017, 10:29   #1
drewkeen
TDI(s): Jetta
Default Mercedes ML Diesel Changes?
Trying to get some useful info on the ML320/350 Diesel and changes they made. All I can find is navi differences, etc.
Seems the major groups are:
07/08 ML320 CDI
09+ ML320 Bluetec
ML350 Bluetec
I see that the 09 got the urea/adblue and picked up a few hp. Did they drop rail pressure or anything else like VW did?
Why do the later cars get a MPG bump over the earlier ones? Any mechanical changes? Lighter?
Any mechanical info would be greatly appreciated!
2002 Jetta Wagon 17/22, 11mm IP, DLC1019, SB Stg II Endurance, FMIC, PD150 Manifold, OMI/VR6 Airbox, 3" Exhaust, Metal Nerd 2" Lift, Skid Plate, CAT Fuel Filter, TD Tuning Race Tune, etc.
drewkeen is offline   Reply With Quote
Old September 17th, 2017, 08:59   #2
PeteZ06
TDI(s): E320 CDI
Obviously the CDI will be most reliable... Straight inline iron block, no diesel emission crap to go bad.
'11 Audi A3 TDI S-Line.. buyback.
'05 E320 CDI
'14 BMW 328xi
'03 4Runner Lifted and fully armored
'08 Suzuki GSX1300BK Full pipe and tune..200+hp
PeteZ06 is online now   Reply With Quote
Old September 24th, 2017, 04:30   #3
moosejaw
moosejaw's Avatar
The ML are V6 OM-642. No real difference between '08-'09 the BlueTech cross over years. In '12 they boosted the output of the OM-642 to 240hp. For the next change over '15 or '16 they went to a 4 cylinder diesel @ 215hp with much higher fuel economy.
My '09 fuel economy is 24 Mpg over 20k of usage. I am not sure about the '08 as my brother drives it, does a lot of idling and doesn't track fuel economy.
The drivetrain is basically unchanged from '06 - '14. 7 speed trans with single speed transfer case. There were some small changes in torque bias front/rear but nothing to note.
2005 MB E320 CDI 155K
2008 MB ML320 CDI 82k
2009 MB ML320 BT 51k
2005 Passat GLS TDI *Sold*
moosejaw is offline   Reply With Quote
Liqui Moly 2005 Diesel Purge - 500 ml Safe to use? ZeroCool Fuels & Lubricants 8 December 27th, 2014 22:18
FS: 1995 Mercedes S-Class Diesel S350 Turbo Diesel, Colorado 84Bruiser TDI Cars for Sale/Wanted 23 November 10th, 2012 15:56
Which way should I go with an ML 270cdi. bqik TDI Power Enhancements 3 September 27th, 2011 09:04
Mercedes R and ML CDI in Fall MoreTDI Non VW Group Diesels 0 May 26th, 2006 22:34
Mercedes Ml CDIs, when do they arrive? Philip Non VW Group Diesels 7 October 27th, 2004 17:07
Page generated in 0.13048 seconds with 12 queries
[Output: 58.00 Kb. compressed to 52.57 Kb. by saving 5.43 Kb. (9.36%)]
