Old April 12th, 2017, 04:45   #46
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
Originally Posted by UhOh View Post
Nice catch, Rem!
Yup, timing got screwed up. And if OP didn't do it then the IP is likely crapped (never did hear, even with the paperwork, where it came from).
There were also some comments earlier in this thread about fault codes related to the Injection Pump. I didn't see any updates on that issue. Now, the timing is out of wack...or the pump head is...or both things are.
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is offline   Reply With Quote
Old April 18th, 2017, 11:55   #47
JettaTDISportwagon
Sorry for the delay in response. I removed the timing cover to attempt to adjust the injection timing with a VAGCOM. I didn't adjust anything because I couldn't get the car to fire back up after the last attempt of bleeding the air out.
JettaTDISportwagon is offline   Reply With Quote
Old April 18th, 2017, 11:56   #48
JettaTDISportwagon
Originally Posted by Rembrant View Post
Wait a second...
What exactly did you do when you removed the belt cover? What did you adjust?
You would remove the belt cover to adjust the injection timing, but not to adjust the IQ.
I'm obviously using the wrong terminology in that statement.
Old April 19th, 2017, 15:48   #49
JettaTDISportwagon
The injection timing was never touched. I was hoping to get some solid help from the forum. I guess when these cars have issues like this there bound for the scrap yard. Anyway timing belt is fine. Fuel pump seems to be fine. it shoots fuel out of the cracked injectors.
Any other suggestions?
Old April 20th, 2017, 12:17   #50
Smokin' Dually
TDI(s): Jetta
Fuel Economy: 18.5 (Hotrodded '94 Dodge Ram 3500)
Did you try the "fuel in a bottle" trick? My first thought was that there is a pin hole in the line inside the tank. Did your sensor replacement include the whole unit or just a sensor/rheostat?
Where in FL are you located?
"With your car, you just have to jiggle the handle." - runonbeer
Her's: '03 Jetta GLS TDI 5 Speed
Mine: '01 Jetta GLS TDI 5 Speed
'94 Dodge Ram 3500 4X4 Cummins w/a smoking problem.
Smokin' Dually is offline   Reply With Quote
Old April 20th, 2017, 12:54   #51
JettaTDISportwagon
I did try the "fuel in a bottle trick" No start. I replaced the whole unit in the tank.
It looks like the send line on the tank sending unit was jerry rigged with a piece of hose and a clamp.
Im located in Sebring
Old April 20th, 2017, 17:05   #52
Smokin' Dually
TDI(s): Jetta
OK, that pretty much narrows it down. Remembering the basics: Air & fuel, compression, ignition & ability to exhaust.
Have you checked to see if the anti-shudder valve is open? I've never heard of it sticking shut but it's an easy check.
I know you've said that there is fuel coming out of the lines when you crank it but I'd confirm that the fuel shut off solenoid is opening and staying open. It's in the IP but I don't have the info to test it at hand (on vac in Lakeland). If you can, like mentioned above, hot wire it from the battery to bypass any possible programming issue or other fun Volkswagen circuitry.
The last thing to check is timing which you could somewhat inspect without timing tools. Pop the timing covers off and rotate the crank until the fuel pump timing holes are lined up. Then check to see if the TDC mark on the flywheel is near the pointer on the bellhousing. (that's the important one) Next, pop the vacuum pump off the end of the head and check the alignment of the slot in the end of the camshaft, it should be parallel to the valve cover surface.
If the pump and crank are aligned, the cam probably is too.
This isn't precise but it should give an indication of the timing being off enough to keep it from starting.
None of this has any association to the 1/2 tank issue. It might be worth checking for recalls on your VIN. Those can be checked here: http://www.vw.com/owners/recalls/
Old April 20th, 2017, 17:49   #53
sisyphus
sisyphus's Avatar
Do you have the timing belt tools? You need to verify the mechanical timing between the crank, cam and IP.
sisyphus is offline   Reply With Quote
Old April 21st, 2017, 05:03   #54
steve6
I feel like with the mucking around that's been done theres a broken wire somewhere now around the IP, or disconnected something... its just too odd off circumstances
steve6 is offline   Reply With Quote
Old April 21st, 2017, 05:19   #55
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
Fuel cutoff solenoid? Apply 12 volts and see if you get a sharp click each time you jump it. Did not read whole thread, maybe you already tried that.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is online now   Reply With Quote
Old April 28th, 2017, 12:03   #56
JettaTDISportwagon
I tried 12 volts and I hear a click. I'll try to get to checking the timing. I agree with Steve6 I feel like the previous owner had issues that he didn't disclose .
I'll try messing with it again this weekend. Work puts me out of town a lot. I haven't had time to mess with it.
Old April 28th, 2017, 12:18   #57
Genesis
Fuel Economy: 53/48/42
Oh yes it does (stick closed)! A friend of mine with a TDI almost had a dealer come get her car over that one.....
Genesis is online now   Reply With Quote
Old April 28th, 2017, 13:25   #58
Nevada_TDI
It won't be 100% accurate, but use VCDS and go to the "Timing Check". turn on VCDS, click on Basic Settings (IIRC) go to group 000, hit go, switch to "other mode"--I am sorry I can't remember right this second, click on Timing select proper vehicle >1995/ ALH/etc. and turn engine over. In theory you should see a yellow line on the screen at least in the bottom section. If the yellow line goes past the top too much advance, if there is no yellow line at all the timing is too retarded.
I have read through this post but it has been a couple of days.. what is your IQ set at? You should also be able to get a reading with the engine turning over and see what it says. There are so many knowledgeable people givings suggestions here I can hardly believe the solution hasn't been found yet.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Old April 28th, 2017, 14:46   #59
UhOh
UhOh's Avatar
Solutions require properly understanding the problem. I think everyone's still working on this part!
UhOh is offline   Reply With Quote
Old April 29th, 2017, 09:55   #60
Chris Bell
A couple of mentions of a stuck-closed ASV, but I don't think you said you eliminated it?
I just went through this with an increasingly frequent intermittent no-start. 20K mi. since an ASV/EGR cleaning and it was already starting to stick.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Frustrated WidTed TDI 101 2 June 25th, 2012 15:05
Getting frustrated!!! zindude VW B5 Passat TDIs 8 May 9th, 2012 18:09
Frustrated!! sharplikestump VW MKIV-A4 TDIs (VE and PD) 15 April 24th, 2012 07:40
Very Frustrated fleuger99 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 35 December 28th, 2009 20:04
Frustrated Waterbug OBD Scanners 6 May 5th, 2003 19:52
Page generated in 0.16044 seconds with 13 queries
[Output: 129.33 Kb. compressed to 108.37 Kb. by saving 20.95 Kb. (16.20%)]
