Old April 20th, 2017, 17:01   #31
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Nicely done!
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old April 20th, 2017, 23:13   #32
eddie_1
eddie_1's Avatar
Felicitari!
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old April 20th, 2017, 23:18   #33
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Top job indeed , the more accurate dyno in the country, WHP
Better quality video:
https://www.facebook.com/vectorcusto...1/?pnref=story
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old April 21st, 2017, 03:04   #34
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
Its same video.)
Thanks for your nice words guys
Lucian189 is offline   Reply With Quote
Old April 21st, 2017, 05:49   #35
diffas
diffas's Avatar
good power but what happens after 4000rpm?
diffas is offline   Reply With Quote
Old April 21st, 2017, 06:11   #36
Lucian189
TDI(s): 3.0 TDI CR
Nothing.
On the road car pulls up to 4700 rpm
Old April 21st, 2017, 06:58   #37
diffas
diffas's Avatar
Yes that "nothing" I was referring to. Not enough fuel? At least on dyno pull it clears up after mid range.
2.5 tdi v6 twin turbo project eliasuk98 TDI Power Enhancements 24 January 28th, 2015 02:13
FS: VNT20 turbo from 2.5 V6 TDI and Injectors bhodgkiss Private TDI Items for Sale/Wanted 9 November 29th, 2014 00:44
V6 TDI With Electric Turbo chewy TDI News/Tech 45 October 19th, 2012 11:31
$4000 Premium - V6 TDI over V6 gasser volkswagendude VW Touareg TDIs 2 May 7th, 2009 21:12
2.5 TDi V6 - New turbo = underboost, then overboost snapdragon TDI 101 1 May 1st, 2007 13:20
Page generated in 0.13010 seconds with 13 queries
[Output: 83.02 Kb. compressed to 72.21 Kb. by saving 10.82 Kb. (13.03%)]
