Matt-98AHU
Is this the MFA you're talking about?On my 2004 Passat TDI is there a way to manually reset the miles to "0" on the center display? I have noticed from time to time it sets itself to 0 or just a few miles left to fill up with a full or close to full fuel tank>>>/???
I have done some reading but not really found an answer, I'm not sure what is going on with how it is the calculating of the distance down to 0 miles to empty....
There's a whole slew of things it can display which you can cycle through with controls on the wiper stalk. MFA 1 is current trip data, MFA 2 is data that is saved from the last time it was manually reset. To reset it, be sure you've selected MFA 2 and press and hold the OK button on the bottom of the wiper stalk.
