Go Back   TDIClub Forums > Forum and Web Page Info > TDIClub and TDIClub Forum News, Issues, Problems and Suggestions
TDIClub and TDIClub Forum News, Issues, Problems and Suggestions This is the place for updates on the website and forums. This is also the spot for forum questions, comments, ideas, gripes, requests, etc. This forum is NOT for posting problems about your car. Non-topic posts will be moved or removed.
Old March 7th, 2019, 15:54   #1
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Default I'm trying to search, I really am...
So I am trying to search for Light Wheels in the NMS Passat forum to see how small and light of wheels people have gone to in the name of economy and just what effects they have seen. But the problem with the search function is that it sees Light Wheels as two separate search terms. So all of the results come back with Airbag Light, Bulb out light, What Wheels do I have, etc.
Is there a way to force the search function to actually do what I want how I want?
Fixmy59bug is offline   Reply With Quote
Old March 7th, 2019, 16:15   #2
JSWTDI09
JSWTDI09's Avatar
I would try putting the search terms within quotes. IOW: instead of searching for light wheels do a search for "light wheels". This should force it to search for those 2 words only when they are together.
Have Fun!
Don
2009 Jetta SportWagen TDI (gone but not forgotten)
2018 VW Tiguan SE (I wish it was a TDI)
JSWTDI09 is offline   Reply With Quote
Old March 7th, 2019, 16:26   #3
I spend way too much time here and am a bit of a wheel slut, and I haven't seen much, if anything, about Passat and lighter wheels. So you may be searching correctly and there isn't anything to see.
Lately I've found that light aftermarket wheels for new VWs are harder to find, and are often larger diameter than I want. My .02 would be to seek out some OE VW 16s, either used or take offs, from a gasser. They won't be the lightest but there are a bunch of styles that look good. And search for a lighter tire.
2002 Jetta wagon, 384K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 260K; 2011 335d, 60K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old March 12th, 2019, 09:53   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
All forum search engines are weak. Use others like google, duckDuckGo with advanced feature, specify site.
Here's a user contributed Google hack-
VW TDI Search Engine
Of course for wheels no need to look TDI specific.
Old March 14th, 2019, 09:01   #5
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
I just want to point out that this particular forum thread is NOT for your problems but rather problems with the TDI website.
I'm surprised, none of you four posters are brand new to TDI!
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Old March 14th, 2019, 13:37   #6
Fixmy59bug
Fixmy59bug's Avatar
Or SUGGESTIONS... After all, it is right in the forum title, is it not?
Then in the forum description, it states "This is also the spot for forum questions, comments, ideas, gripes, requests, etc"
I was asking for help, also known as a suggestion, on refining my search terms.
Can you think of a better place where one might seek help on using the forum features?
Old March 15th, 2019, 12:58   #7
BobnOH
not-a-mechanic
Yes, fine, but this more of a forum forum. Car stuff will be in 101 or the model specific forum. Also Power Enhancements, but the other 2 get a lot more traffic.
http://forums.tdiclub.com/
Old March 15th, 2019, 15:15   #8
jayb79
This may be handy:
https://www.myturbodiesel.com/1000q/...y-database.htm
01Golf(410k) 50-52 summer mpg, 2013 Mustang V6 28-30 summer mpg, 2016 F150 RCSB 2WD 2.7L ecoboost 25-27 summer mpg.
jayb79 is offline   Reply With Quote
Old March 15th, 2019, 18:35   #9
Fixmy59bug
Fixmy59bug's Avatar
Thank you bob....
But in case you missed it the first two times, I am asking for info on how to refine my search input. You know... HELP ON USING THE SEARCH FUNCTION.
I am not asking this forum what are the lightest wheels for my car. I am asking how to search for the lightest wheels because the search function doesn’t combine words in the search function.
Regardless, I think a mod can go ahead and close this thread as it has run its course.
Search? Gluhkerze TDI 101 3 September 25th, 2011 21:34
Using the search TDIgurl35 TDI 101 6 April 10th, 2008 10:03
Tried the search - still have to ask. Look4ward VW MKIV-A4 TDIs (VE and PD) 2 June 14th, 2004 10:30
Search cloute Quebec 3 January 19th, 2004 17:27
Search Could be Better VelvetFoot TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 1 April 2nd, 2003 06:11
Page generated in 0.12239 seconds with 12 queries
[Output: 93.86 Kb. compressed to 80.33 Kb. by saving 13.52 Kb. (14.41%)]
