Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old March 15th, 2019, 10:12   #16
Powder Hound
Powder Hound's Avatar
Fuel Economy: pretty freakin' good.
Originally Posted by MAXRPM View Post
...so to say additives do not do anything I would say it depends how you lay it out, real test is to have the pumps withoout additives and issueless for so many years and miles in the car.
Hence, without double blind studies, which would take many years and a budget measured in cubic dollars to perform, a definitive empirically generated answer is not possible.
Cheers,
PH
Thinking outside the box is difficult for some. They're afraid they'll fall off the edge of the box and be lost to oblivion.
Powder Hound is offline   Reply With Quote
Old March 15th, 2019, 14:39   #17
BeetlePD
TDI(s): Beetle 2005
Originally Posted by Powder Hound View Post
At least post the url. You could be manufacturing this 'study'.
. I read it YEARS AGO so should I memorize web addresses that old? Anyway I googled it for you and found this : Not sure if it’s the same study but it looks similar
https://www.epa.gov/sites/production...r_korotney.pdf
If you really feel that everything US is bad, then STFU and please leave! I
Wow
BeetlePD is offline   Reply With Quote
Old March 15th, 2019, 16:18   #18
MichaelB
Fuel Economy: very good
According to that study that you just posted higher cetane numbers reduced the Nox not increased it so it was not vetoed because of increased Nox. It was determined that that increased cost would deter the buyer from purchasing it, This is also taking place in 2003 and totally irrelevant to low cetane destroying your car's engine.
This is from that study:
"typical" cetane increase of 5 numbers will produce a 2.1% reduction in NOx"
MichaelB is offline   Reply With Quote
BEW engine - block damage oil starvation - damage inspection kraftwerkturbo VW MKIV-A4 TDIs (VE and PD) 7 February 14th, 2015 10:32
Octane boost vs. Cetane boost addatives question lovesTDI Fuels & Lubricants 6 February 7th, 2010 19:16
Can cetane improvers/additives cause damage? MalcolmBurke Fuels & Lubricants 13 April 24th, 2007 10:08
Cetane boost turbo_dse Quebec 7 October 10th, 2005 14:50
Biodiesel + Cetane Boost=less engine vibration delste Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 4 December 4th, 2004 21:48
Page generated in 0.10327 seconds with 12 queries
[Output: 63.80 Kb. compressed to 58.13 Kb. by saving 5.67 Kb. (8.89%)]
