LindenKeith
I am still having cold start problems. If the temp is below 25 degrees F. The glow plugs warm up and the car starts right up! If the temp is above 25 Degrees F the glow plugs do not warm the engine and the car takes quite a while for the car to start. I have replaced the glow plugs and the Coolant temp sensor and it is still having the same problem. If I unplug the coolant temp sensor the car starts right up. Any suggestions?
