Hey guys so I have a 02 golf manual Alh tdi , it sat in the cold over night with a glowplug issue , the starter went (I could hear it acting up ) pulled the car in and took off the stater, luckily I had a spare and bench tested both , mine was not engaging the solenoid so I put in my newer one
After I turned the key and it started up , but I was in my garage with the door closed so I shut it off after about 20 second max, after I rolled it out and tried to start it up again to let it run , No start, I thought battery so I boosted it had good lights on dash tried again no start. Pulled it back in check for air in the fuel lines and there’s about a two inch long gap in the clear fuel line from the fuel filter to injection pump. So I thought bingo that’s my issue , picked up a handheld vacuum pump thing , and continued onto bleeding it from that Little valve at the return line ( I watched a few videos to make sure I bleed the right spot )
So while I’m doing this the two inch long airline isn’t going away but I’m still drawing deisel into the container, with big bubbles at first and then proceeds to just constant mini tiny bubbles. If I tap the two inch long air gap in my line ALOT more bubbles come out , do I have a faulty injection pump or maybe some leaks somewhere ? I don’t seem to have any deisel coming out from anywhere, it’s dry. I’m not sure what to do next I’ve researched the common threads if it won’t start but can’t narrownit down and don’t want to keep attempting to turn the key
I have a Parts car with a seeized motor and another motor blown from my other car , so I have spare parts I just don’t want to bring it to a shop me and my friend have swapped this motor when my first one blew , that was 200xxx kms ago because of a faulty belt, so we can usually figure things out but this one has us stumped. Any help would be very appreciated.
Thanks guys
Thanks guys
