So here it goes. I bought a 2006 Jetta off a "friend" that was supposed to have a brand new center housing on the turbo and run really well. It had the colt cam, timing belt, etc installed around 40k miles ago. He delivered it and we drove it 15 or 20 miles with no issues so I took it. It's sat for about a week and I went to drive it and went into limp mode and threw a p0299 and p0102 code. I started messing with it and there was no vacuum line hooked to the nipple coming off the pump. I figured it had just come off. When I hooked that up, it won't move hardly. Smoke dumps out the exhaust. Give it a vacuum leak again and it runs good again till limp mode. I changed the n75 valve (it was bad). The vanes are staying fully open. I'm wondering what can cause this? I checked pulse that tells the turbo how to move. If I ground it with a probe, it adjust the actuator rod to where I believe it needs to be. Could this be a computer issue? Or has anyone had this kind of issue? The lines are routed correctly according to vacuum diagrams. Any help would be great!
