Egt and boost gauges
Speardog
Ft. Lauderdale, FL
2000 Jetta 5 spd black
I'm going with a stage 2.5 or 3 rocket chip tune soon and wanted to get an affordable egt and boost gauge setup. I don't want them on the a pillar. Anyone have suggestions?
Corsair
Weedsport, New York
2002 Jetta GLS TDI 5M
There is a 2 gauge pod available that sits atop the steering column, locates the gauges just behind the steering wheel, in front of the instrument cluster.
Celco
Warren, MI 48092
2002 Golf 4dr ALH 5-speed
http://www.impconcepts.com/vwgolfboostgaugeforsale.htm
If you want to get really fancy!
I was planning on buying the built it yourself kit from that guy, but I ended up passing for the moment. I started to think about all these new maker homebrew things with arduino units, I think I am going to take a stab at building a shield and mounting for andruino run boost and EGT led gauges integrated in the cluster.
