Smkn600ctd
2013 Passat SEL 46k miles
On acceleration from a stop, there is a rotational noise/groan. 5-10 mph light pedal on take off. You hear it and you can feel it in the floorboard in the front. It’s hard to describe the noise. Sounds like a old metal spring squeaking noise but it rotational means as your taking off it comes and goes as the wheels are rotating
Jacked it up. No noise. Started it up and put it in gear while jacked up...no noise.
Drive it around there is noise, but not every time. Only does it while on the ground, weight on the wheels.
Dealer had it today, of course they don’t know what it is, can’t duplicate and can only hear the turbo spool valve???
Ideas? What thinking it’s a wheel bearing or a drive shaft.
