Old October 1st, 2013, 16:53   #46
wmhjr
Originally Posted by tadawson View Post
For what it's worth, mine got the new FW within 5 days of purchase, and I never looked back. I'm not certain, but I recall LokiWolf saying that he also has the old stuff, so you could always roll back if needed.
Considering that this is not a 'hard' or irreversible change, I don't consider warranty issues of much significance. If all else fails, perhaps another member with the new FW could let you try thiers before you make a decision.
- Tim
Is it possible to roll back the firmware? Though it's only SW, it's not uncommon for rollbacks to be impossible. We're talking about a $30K decision, so....
wmhjr is offline   Reply With Quote
Old October 1st, 2013, 17:29   #47
LokiWolf
LokiWolf's Avatar
It is possible. If you are trading it in, I would not recommend it. As I am sure you know doing it once yet 2 times is just asking for something to go wrong.
2013 Passat TDI SEL (Daily Driver)
LokiWolf is offline   Reply With Quote
Old October 1st, 2013, 17:48   #48
LokiWolf
LokiWolf's Avatar
I started an IT career a long time ago, with my first network certs back in the days of ArcNet and Token Ring. Now I run a very very large enterprise.
So, I am a Network Analyst in a VERY large organization, with over 60,000 users, I have MANY IT certs, including several from Cisco, Several from Microsoft, one from Redhat, one from VMWare, and few others. They mean squat when talking about the RNS-510.
What I was NOT familiar with is what the V5.2M disk was. It is not clearly labeled as either, and I had no idea what was on it.
What do you mean it isn't clearly labeled? The disc itself, clearly says Navteq maps, the instruction sheet you have referenced that came with it clearly says, "Update of Navigation data base". They are the FIRST 5 words on the piece of paper.
From what you're saying, it's just a map update - which will essentially give me back a unit pretty much like I dropped off.
That is EXACTLY what I have said more than once, other than it will improve access speed to the MAP data, because of a revised index.
It will apparently NOT update my firmware. Even my searches today on this site are not terrible clear about that but it's what I'm finding.
What do you mean CLEAR. I said it at the start of this thread, I said it in replies to you, I even stated it in the other threads that now link to this one. I COULD NOT MAKE IT ANY CLEARER!
My impression here is that I'll get the car back with the same 3696 firmware, and the dealer will not be able to change that.
Most likely, unless they have taken it upon themselves to get a copy of 4366, or VW has FINALLY provided it to the dealers.
Based on this, I'll likely be giving the Passat back to VW and getting my money back.
Good. I hear the new BMW 3 series now has a diesel for the US. Since you have been doing IT so long, you should easily be able to afford that.
For the unlock, I don't lock the car at my location. Ever.
Pressing the unlock on the remote, even when the car is already unlocked, will start the boot up process.
I'm not comfortable putting a firmware version on outside of warranty considering that I'm very possibly returning the car. I want zero chances of VW trying to say I've done anything wrong whatsoever. If I had owned the car for a year or so and there was no chance of this, then I'd go for the firmware update because after all, the unit is crap as is. However right now I need to stay the course without modifying the unit outside of VW. I am seriously curious as to why VW would decline from making the newer firmware versions available to customers who are clearly suffering from performance issues.
I agree, do not load the firmware unless you decide to keep the car. I will not be discussing this anymore with you in this thread. This is EXACTLY what I did not want to happen in this thread. If you decide to keep the car, PM me, and I will gladly send you the Firmware download link.
Loki out.
Old October 1st, 2013, 23:06   #49
JimPhazer
For those with a 2014 Passat SEL. The VIM ReCode works great. Had to hit the 3 finger reboot with the Disc in the drive, but it only took a minute to load and unlock VIM. Here is the version info that came with my 2014.
HW: H21
SW: 4369
Map: 7963
JimPhazer is offline   Reply With Quote
Old October 2nd, 2013, 00:23   #50
CNNPress
Fuel Economy: 33/48
Nice! You have SSD!
Sent from my LT28h using Tapatalk 4
CNNPress is offline   Reply With Quote
Old October 2nd, 2013, 05:40   #51
APT
Thanks Loki for organizing the details!
2012 Passat TDI SEL Night Blue/Cornsilk
2017 Subaru Outback 3.6R Limited Lapis Blue
2011 Suburban 2500 family towing beast
APT is offline   Reply With Quote
Old October 2nd, 2013, 10:33   #52
tdrag97
Thx Loki.. update to V5.2 map with the disc from VW. took awhile too
Look like I would have to get your new FW to speed thing up a bit. Anything would be better then now.
Currently I have 13' SEL with VIM (from recode_VIM_berto89)
HW - H02
SW - 3696
Map ver - 7994
tdrag97 is offline   Reply With Quote
Old October 2nd, 2013, 10:47   #53
panther_v
Thanks to Loki, I successfully updated to the new version.
I'm curious on a few things though:
1. 7994 (V5.2) is a reorganized version of 7870 (V5), but both has same content. How about 7963? Does this version have the same structure as 7870 or the database structure of reorganized 7994 (ie improved access...)?
2. If I decided to move back to V5.2, will the system allow me to install an older version? or it is not backward compatible?
panther_v is offline   Reply With Quote
Old October 2nd, 2013, 11:26   #54
JM Popaleetus
JM Popaleetus's Avatar
And some say I derail threads. Returning a car because VW needs to push out software updates ?
ANYWAY. Loki, as one of your original beta testers. THANK YOU for all the work you've put into this!
My original review:
Preface: Do not expect it to be as fast or smooth as a dedicated Garmin GPS, your iPhone/Android, or anything else stand-alone. With that in mind, the update is a NIGHT AND DAY difference in my opinion.
The interface is the same (and relatively unintuitive) however the severe lag is gone. Things actually happen when you press a button, and the touch screen reacts as good as a non-capacitive touchscreen can. It also starts up and switches to the rear cam much faster.
In my opinion the system is now as good as the RNS-310 and RCD-510, and in the end, this update should fix a great majority of peoples complaints. It's still not the best in the industry or the next version coming in the new Golf. It is however good enough to keep me from buying a replacement in the immediate future or feeling burned by VW.
Cliff Notes: This update definitely makes the 510 usable and I hope VW rolls this out as a recall. Don't expect it to be as fast an iPhone however, it's more like an ATM now.
And some update/troubleshooting tips:
  • The Star button next to the CD drive is what the firmware refers to as the Night/Day button.
  • Make sure you have your car set to 24hr mode (do this via the time setting in the MFI).
  • I was unable to do the update in accessory mode. This was frustrating to figure out with Kessy. Just unlock your car and push the radio's power button.
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium Buyback
2010 VW Jetta TDI Buyback
JM Popaleetus is offline   Reply With Quote
Old October 2nd, 2013, 11:33   #55
tdrag97
  • Quote:
How does this help if the car is in 24hr mode or not?
Old October 2nd, 2013, 12:27   #56
JM Popaleetus
My radio wouldn't allow the update unless it was in 24hr mode.
Old October 2nd, 2013, 13:38   #57
Checker39
Default Source for 4366 firmware?
Thanks, LokiWolf for posting this information. I have pressed my dealer without success for any available firmware upgrades to improve the performance of my RNS 510 [2013 Passat SEL TDI purchased May 2013].
From this thread and searching for related information, it looks to me like my dealer will not be able to upgrade my firmware from 3696 to 4366, even if I provide the service manager with the version number. Is this correct? If so, am I relegated to purchasing a DVD for the upgrade from a third-party supplier? In previous threads I've seen mention of someone seloing a DVD for $185. What's the best source for the software? I located someone selling it for $31 here, http://www.qmstore.com/VW-RNS-510-20...e/p223907.html, but I have no idea of the reliability of this vendor.
Thanks again, and I apologize if this has been all covered before but my search did not turn it up if so.
Checker39 is offline   Reply With Quote
Old October 2nd, 2013, 17:14   #58
tadawson
FWIW, mine did fine on the first try in 12 hour mode . . .
- Tim
tadawson is offline   Reply With Quote
Old October 2nd, 2013, 17:15   #59
tadawson
No, you get it here for $0 . . .
- Tim
Old October 2nd, 2013, 17:29   #60
ChrisB009
Looking for this update...can someone message me a link where I can dwload?
Thanks,
Chris
1985 CJ7, 2003 Silverado 2500 Duramax/Allison, 2008 Ford F450 King Ranch Edition, 2013 Ford Focus SE, 2013 VW TDi SEL, 2017 Subaru Legacy Limited, 2007 Yamaha FJR-1300, 2009 Kawasaki 650R
ChrisB009 is offline   Reply With Quote
RNS-510 Latest Firmware, 5M Maps SVTWEB Private TDI Items for Sale/Wanted 4 November 1st, 2012 06:53
Rns510 & 9w7 myriad VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 November 19th, 2010 11:19
Hey locals... pump rebuild & info thread michael. West Coast Canada/USA 11 August 12th, 2009 12:02
2 & 3 bar maps Ynot TDI Power Enhancements 8 June 25th, 2005 07:56
Page generated in 0.21099 seconds with 11 queries
[Output: 137.54 Kb. compressed to 116.22 Kb. by saving 21.32 Kb. (15.50%)]
