Old November 27th, 2013, 14:19   #46
South Coast Guy
Fuel Economy: Good
Originally Posted by ChadS99SVT View Post
I just got a quote from one dealer I frequent. $857.00 for the 40k+Dsg service.
He mentioned how to get a 15% discount but ugh hoping I can still find it cheaper than that at another dealer.
I have another month or so.
Some of the service you can easily do yourself; chaning cabin and engine air filter. Check local dealer websites for service coupons. I found one for 15% off any service and had that dealer service my DSG transmission. Clossest guro to me is 2 hours away, so not practical for me.
South Coast Guy is offline   Reply With Quote
Old December 21st, 2013, 18:19   #47
r11
OK, did mine using the warm and dry weather we had today here in nj.
The plastic engine cover is friction fit, lifts right up, no tools required.
2012 takes 4.3L of VW-507 spec oil .
Use plenty of paper towels to mask and protect against the spills during the service.
I use plastic Rhino ramps for a number of years and a whole range of different cars, highly recommended.
To my surprise, oil filter came out very easily. The service crew at the dealer had already moved the wiring harness out of the way during the previous changes. All I had to do was tilt the filter a bit to the right and it came right out.
When doing visual inspection of the replacement filter it might look slightly different from the old one, there is a reason for it - paper on the bottom of the filter gets pushed in around the inner hole when it is inserted into the housing.
The bottom pan had 3 rear screws missing... Another reason to service your car yourself. What size are these ? I now need to acquire the replacements.
When putting new filter in, I placed the paper element into the housing first and then installed the top part. Don't forget to replace all 3 o rings. Lubricate all of them generously with fresh oil, especially the big one.
Fuel filter was a piece of cake. I removed the old one, SLOWLY, making sure I let most of the fuel drip back into the housing.
Then I SLOWLY sunk the new filter in. She started with may be 4 second hesitation. I do have a vcds, but didn't have to use it to prime the filter.
Did the air filters too, real easy stuff.
Yet to pour the DEF in, will do it tomorrow. Got "Peak DEF" at local auto parts store, 12 bux for what seems to be 2 gallons. I guess these are all the same.
Sent from my Nexus 10 using Tapatalk
r11 is offline   Reply With Quote
Old December 23rd, 2013, 08:30   #48
vw_norm
Gone, but not forgotten.
from partsbase.org: N 90735604 hexagon socket head bolt with. hexagon socket head bolt with; shoulder; M7X28
When I dropped my oil pan to install the oil sensor, I was surprised by the number of 'barely' torqued bolts I came across. When yours came out, they were probably still on the splash shield, which you dealer dumped on the prior service. Always best to do your own servicing.
vw_norm is offline   Reply With Quote
Old December 29th, 2013, 16:32   #49
Robsride2
My dealer charges 302.27 for the 40K on the 6MT. They gave me the pricing when I had the 30K service done.
Robsride2 is offline   Reply With Quote
Old December 30th, 2013, 13:54   #50
lojeff10
Amazing how different from one dealer/area to another.
lojeff10 is offline   Reply With Quote
Old January 10th, 2014, 13:46   #51
Herkguy
Fuel Economy: @75-80mph w90/10 hwy/city. warm wx-45, cold wx 39
Stonecrab, any chance you could post a copy of the receipt for the 40k service with DSG? My dealer wants 856 to do it but said they would match any other vw dealer so I would like to bring a copy in to show them.
Thanks Eric
Herkguy is offline   Reply With Quote
Old January 17th, 2014, 19:40   #52
StoneCrab
StoneCrab's Avatar
Thanks Eric
I'd be happy to but don't want to post personal info. And I bet they wouldn't accept a partial or redacted copy. I did have a 15% off coupon which they applied to the whole service too. I have been very happy with my dealer's service department. I think the DSG service is too expensive but that isn't the dealer's fault. PM me for more info...
StoneCrab is offline   Reply With Quote
Old January 19th, 2014, 10:14   #53
mikeymike214
Location: Belleville, NJ for now plan on moving next year.
ok im confused... im still under the 3 year maintenance warranty. from reading on this thread it seems that the dsg service is out of your own pocket? why isnt the dsg part of the warranty?
mikeymike214 is offline   Reply With Quote
Old January 19th, 2014, 10:30   #54
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Because the first DSG service (at 40k) is after the 'free' maintenance ends (36k up to '13, 24k for a '14).
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old January 23rd, 2014, 17:35   #55
Bobmws
Had my 20k today, my dealer is good. I've told them going into the 10K that I would check everything before signing the invoice copy. Haven't seen an errant oil, fuel or Adblue drip, and all levels are perfect. I asked about the 40k/DSG service and was told ~$500! I can live with that.
Bobmws is offline   Reply With Quote
Old January 28th, 2014, 13:27   #56
cevans
TDI Parts Ninja Vendor
cevans's Avatar
$500, and you are okay with that!? You can buy the parts for about $100 and pay yourself $400 for the DIY!
IDParts.com - IDParts.com Vendor Thread - The IDParts Blog - IDParts YouTube Channel
Current Diesels: '17 Canyon 2.8L DMax, '15 Jetta, '15 Beetle Convertible, '11 R350 BT // Past: 15' Ram ED, '13 NMS, '10 JSW, '10 Jetta Sedan, '07 R320 CDI, '06 E320 CDI, '03 Wagon, '00 Golf 2-Dr, '00 NB (Yellow :-)
Stop Hunting for Torque Specs - Get A Free IDParts Torque Spec Poster Today!
cevans is offline   Reply With Quote
Old January 28th, 2014, 13:30   #57
cevans
cevans's Avatar
I find the concept of "40k" service amazing - last time I got whacked for about $500 and, when I asked what was done, they didn't' even replace all the filters.
You can do all the filter and the oil yourself for under $125, or pay a local shop a VERY generous $100 to do it for you and still save a lot of cash.
Old January 29th, 2014, 05:04   #58
Bobmws
Yes, I am, hone up on your reading skills.
I have faith in people I deal with face to face, not so much some one who solicits me on the internet.
FWIW, I do have a small business with a website, but I don't make a practice of prostituting myself by jumping into a thread and criticizing someone's choices.
Old January 29th, 2014, 12:38   #59
Rico567
Wink
You, sir, are my new idol.
[URL=http://www.fuelly.com/driver/rico567/passat]
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old March 9th, 2014, 12:32   #60
Rico567
It is no doubt time consuming, but I believe it's the way to go when this "free service" runs out. I've been having a hard time rationalizing the purchase of VCDS for personal use, but since we've got a DSG, well, the first time I service it the VCDS will basically be paid for.....
- Adam Savage
Has anyone use Wheaton Service center in MD for a 40K Service with DSG change? j1mbo Eastern USA 6 September 11th, 2014 05:36
First DSG service, 40k service done! Jav9882 VW Passat Family (NMS and B7) TDIs (2012+) 8 April 27th, 2013 06:03
40k service checklist pkhoury VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 July 23rd, 2012 12:12
20,000 mile service - checklist torifile TDI 101 18 October 19th, 2006 00:20
40K Service Checklist BoraTdi VW MKIV-A4 TDIs (VE and PD) 7 December 9th, 2000 01:47
Page generated in 0.16395 seconds with 11 queries
[Output: 134.27 Kb. compressed to 113.22 Kb. by saving 21.06 Kb. (15.68%)]
