"Hey, why didn't you mention that in the thread? Lol. That's pretty clever actually - though alignment of the laser with the back tires may be difficult with a common laser pointer. Before my diesel addiction, one of my previous hobbies was lasers... I've spent a lot of money on some some high powered lasers and cheap ones alike and unless you're buying a quality lab laser, the beam will not leave the pointer perfectly perpendicular to its aperture. Also, you'd need to have a laser with a high quality lense if you plan to notice very subtle differences, as most lasers have a bit of "splash" around the spot; splash increases dramatically the closer you get to the spot, sometimes making it difficult to tell exactly where the spot begins.
Not knocking your idea - as you said it's what the professionals use. I'm just thinking that unless you have a "professional" quality laser, it may have another set of variables. Either way, I'd love to give it a shot - has anyone else tried it?" RobRou
Thanks for the kudos, but I just thought of it. Me, I take it to the pros for $60, they can get it down 10-20thou. Try and do that with a piece of string. Now if you take piano wire and a turnbuckle and some really solid mounts for aforesaid wire, a steady hand and some calipers, you might get close.
Just thinking that with a ruler and a 1/8" dot you could get down to a
1/16" without the problems of a flexible reference point. Laser levels have made construction/building layout a lot easier. I've used water levels and piano wire to setup for boatbuilding, but it would have been a lot easier with a laser.
With a good steel rule, setup an inch off the rear tire hub and then check the front. I assume front and back have the same track width?
Or find a 16' straightedge. Dunno', like I said, for the kind of precision required, and a one of setup, I take it to the shop.
For the OP, and somewhere out in the boondocks, might be worthwhile setting up something.
