Suzuki_dude
I've been a long time reader of the forum and decided I'd join it and share my TDI swapped Sidekick. It's a '95 that originally had a 1.6L 8v engine and 5 speed transmission. With the oversized tires it would do 0-60 in about 20 seconds. Mileage was around 25mpg. I averaged about 37mpg after the swap. My best was 39.5 so I'm pretty confident with taller, skinnier tires or a gear swap it'll do over 40 next summer. It has an AAZ exhaust manifold, turbo and non-EGR intake from my parts car, pp520 nozzles, and Malone stage 3 tune with EGR delete obviously. The non-EGR manifold looks better than an EGR manifold and block off plates. Bought the engine with a busted timing belt planning on using the crank in an AAZ so I'd have the D shape sprocket. After tearing the engine down and finding the bottom end was fine I decided to scrap the AAZ plan and go TDI. The head was rebuilt with all new (not Chinese) parts and has ARP studs. My first time taking an engine apart. My dad and I assembled it ourselves with a borrowed valve spring compressor. I wish I had a picture of the head after it had been cleaned. It looked awesome. So clean. Anyway on to the pictures.
Engine and Toyota W56 bolted togther with the Acme adapter which I later found out sucked.
3" exhaust because I can. I know there's no performance benefit.
Built a bracket to hold the fuel filter. Got the base thing from one of my dad's scrap semis. Overkill but same price as a new OEM filter. Bracket has cracked and I gotta make a new one a bit stronger.
Here's my modified oil pan to clear the front diff. Took a few days of trial and lots of error.
Modified pickup tube using a combination of the stock AHU, stock Sidekick, and big block Chevy aftermarket pickup. You can also see the modified windage tray. Got it in one of my AAZ parts cars so figured I might as well use it.
Engine during test fitting in the parts truck. Top rad hose came from my '93 Passat AAZ with a couple bends cut off. Fits perfectly.
Big eBay intercooler. When I opened it I was a bit concerned it would be too big to fit.
Thankfully it fit just fine with minor cutting near the passenger side headlight.
Here's the best pic I have of the intake setup. Has a much better filter on now drawing air from inside the passenger fender. From the turbo it goes down to the bottom pipe of the intercooler. The straight sections are 2" stainless milk pipe my dad got as scrap metal. Really awesome living on a scrap yard. This was still testing fitting phase. Clamps were added for the actual swap.
Radiator was given to me by a friend. Came out of a scrapped 2nd gen tracker. Notice a trend with the scrap parts? I don't have a picture of it but I got a thermostat housing spacer to avoid the U bend coolant hose by the driver side motor mount. Got the spacer drilled and tapped at a local shop to fit the VW fan switch. It runs so cool the fan never came on and it never overheated.
