HOOPER65
Thanks - a useful & educational conversation.As previously stated, unplugging the CTS results in the ECU having a reading that defaults to minus 40c. The use of Vag Com Diagnostic System (VCDS) verifies this ....... thus no Theory. This will cause the GPs to glow as well as an increase fueling.
Bump/roll/kick starting is just a means to rotate the engine fast enough (at least at the rate of 250 RPMs) to create compression sufficient enough to ignite the fuel upon injection. Obviously, the ignition needs to be in the ON position for at least three reasons 1). so you can guide the vehicle, 2). so the fuel shut-off/on solenoid is ON. and, 3). so the GPs will glow if necessary (with the CTS unplugged, they will glow).
Under different circumstances in a less congested parking lot
or with a hill available, I'm sure the car would have stared.
Where I was stuck, I think flashing the plugs
would have helped obtain combustion.
All good info should I run into this again, or can assist others.
