ken2116
I have just started trouble shooting a 2002 Jetta (128kmi, owned since 106kmi) that cranks well but won't start following a 3mo. period of non-op while vacationing. Battery was disconnected while gone, held charge and is topped off. Dash indicators appear okay. Fuel tank full. It's hard to see for sure whether there is fuel in the transparent line at the filter, but it may be empty.
- Will start with a fuse and glow plug check.
- What is the proper way to check for fuel delivery, pressure?
- Where should I listen to hear the main fuel pump (not sure of location)?
- Is there a recommended shop manual?
- Is there anything else? Other links or places on the forum I should check?
History: replaced EGR valve a year ago (diaphragm leak), ran fine both before and after, the CE light stayed off after the repair. A rodent once chewed through an injector return line (it ran but leaked and smelled of fuel) and ran well after replacement. No rodent nests of damage evident this time.
Update 11/2/2017:
Thanks to all for the useful information, here's the latest:
1. Removing the inlet line to the fuel filter one can freely pull fuel from the tank. Replaced line.
2. Removed injection pump feed line (the clear one from the filter) from injection pump (IP) inlet and can freely pull fuel until bubbles are purged using a floor standing Mityvac extractor.
3. With the clear tube full the rubber portion of the hose near the IP was pinched off and fuel remained bubble free until the tube was over the IP nipple and the pinch removed, afterwhich the tube drained completely (hose clamp not in place yet, don't know if that mattered).
4. Pinched tank return hose at the fuel "T", removed return line from Injector 4 and applied vacuum to the return line end of the IP with a catch bottle before the Mityvac. Captured perhaps an oz. of fuel in the bottle and pulled air (slowly) for over 20 min. at vacuum levels ranging from 5 to 15in., repumping once or twice. When doing this with a hand squeezed Mityvac the vacuum level bleeds from 15in. to near zero in ~ 10-15sec. - energized the fuel cut-off solenoid for a minute or two but it appeared to make no difference to the flow or leak down rate. Listened around the IP but couldn't hear sounds of air leaks.
5. The fuel cut-off solenoid valve at the IP receives 12vt. and clicks when the key is turned on and also responds to a direct jumper wire to the battery.
6. Disconnecting the clear fuel line to the IP at the filter while applying 15-20in vac. at the IP return line (Item 4) - one feels only the slightest vacuum, almost none, when placing a finger over the IP inlet line indicating that there is very little draw from the filter. The rate of air drawn from the return line and bleed down rate of the vacuum remains unaffected whether or not the IP inlet line is blocked or open to air.
Update 11/18/2017 (twice):
7. Rigged a 16oz. bottle above and directly to the IP through an inline filter, pressurized with hand Mityvac, feeding most of the bottle to the IP. Noticed fuel dripping from below the IP on driver's (output) side, but couldn't locate source.
9. Loosened nuts at No. 3 & 4 injectors and cranked starter until fuel flowed from nuts (~ 5 sec). Tightened nuts - Cranked, fired a few times though didn't start.
11. While cranking noticed a ~ 1/16in. dia. free stream of fuel squirting to right (toward drivers side) from under drivers side of the pump, which continued dripping for a while after cranking. The stream appeared to be coming from either the very bottom of the pump or just below it. It does not appear to be coming from either of the large rectangular gaskets that seal the major components of the pump case.
Questions: Are there any easy suspects such as rubber hoses under the pump that may be leaking (chewed by rodents, etc.)? Pressure relief valve on pump, etc? Anything else to check before diving in for inspection, seal replacement, etc.?
Will look at IP related posts and links, including those contained in Joester post of 11/15, but would appreciate suggestions for specific links as I miss something. Also, have washed hoses and wiring that got splashed.
Thanks.
Update: 02/02/2018: Determined that the head o-ring must be leaking and am ready to try replacing the o-Ring without removing the IP QA cover. Have the viton o-ring (and spare) from Dieselgeek. Have studied the stepwise instructions for o-ring replacement by stretching it over the head.
Main question: to ensure the IP plunger is at full stroke, specifically how should I rotate the engine? Will remove the timing belt cover per the instructions on the belt change - is it okay to put a socket wrench on the cam pulley nut and torque it from there (CW as one faces it), or do I need to turn the cam with the lever tool made for the purpose? My concern is if there would be a risk of over torquing the nut, etc.
Second question: I've read that it's not necessary to do this with this particular engine (2002 Jetta) because the plunger always is under compression, is this really true and am I being over cautious? It would be easier if I didn't have to expose the timing belt, but would hate to learn the hard way. Would prefer answers from those who know for certain, as opposed to well meaning opinion. Thanks.
Update 11/2/2017:
Thanks.
