dieselectric
Hi Tdi-Club,
Long time viewer and gleaner of TDI knowledge, but finally created an account and am sharing my project.
Once I find an alternate image host (no thanks Photobucket) I will post photos of my project...but for now I wanted to share where I am at and ask a question.
Many years ago I purchased a wrecked 1996 TDI Passat - running driving, but hit in front. About 5 years ago I parted it all out and was going to put the motor in my VW truck. Then I went to Germany for a year, came back, got into other projects, and plans changed.
In March I bought a 1977 Scirocco without engine or transmission : perfect candidate for a restoration and TDi conversion! My first car as a teenager was a Scirocco, as well as my 3rd and 4th car as well.
I disassembled the 1Z motor, had the block cleaned, checked and honed by a machine shop, and the crank polished to remove some light scoring. I just painted the block Buick Green with POR-15 engine enamel, and am about ready to get the motor back together.
I have a question about the single-use rod/main bolts, and checking bearing clearances. I want to plasti-gauge the new rod and main bearings to make sure clearances are within spec. But the bolts are single use. So my question is : What torque to I take the bolts to, to get an accurate clamping pressure without having to buy new bolts?!
Thanks in advance for your insight.
