TDI_Michael
Cleaning out wifes intake manifold on 02 Jetta and wound up stripping the threads while installing one of the six manifold bolts while putting it back together. Would a helicoil work in this situation or should I try to rethread the hole to a larger size? Not sure of the manifold bolt size (N90424201) or which helicoil/tap I should use so any help would be greatly appreciated.
