Kurt13rager
I have a 2001 Jetta TDI ALH that is having major over pressurization of the cooling system. I have replaced the water pump with a metal impeller style water pump as well as the thermostat about 30k miles ago. I had also changed out the head gasket at that time as well. The reason being that the previous owner couldn't keep oil in the engine and spun a rod bearing and bent the crank but that's another story. The block had been replaced at that time as well. Back to the issue at hand. I can't keep coolant in the engine long at all. I can drive maybe 10 miles up the road and then I have a puddle of coolant under my expansion tank and on the ground. About 2 months ago, I hooked up a garden hose and ran it through my system to see if I had any blockage and it seemed to flow well. At that time, my car still produced heat through the heater vents and I could get many miles without filling up the coolant. As I stated earlier, I can only get about 10 miles or so before it overpressurizes and blows the expansion tank. I do not have any heat coming from the vents at all at this point. I was thinking possibly the head gasket was allowing gases in to the coolant causing the overpressurization but now I'm not sure. I have the gasket in hand and was ready to tackle the head gasket this weekend but I do not want to jump in to that and it not be the issue. What are your thoughts? Possible blockage somewhere like the radiator or heater core or even the head? Is it likely to have a bad water pump with the updated metal impeller? Bad thermostat? Any thoughts or suggestions are very welcomed. Thank you all in advance
