Please can someone help me with a problem I have with my golf? The car whines/drones as I drive. It sounds as if I'd got tractor tyres fitted. The noise is constant and just increases/decreases in pitch according to speed. It makes no difference if i'm in neutral or in gear apart from the fact I can hear it better when in neutral. I've also tested it going around corners and that seems to make no difference either.
Today I chocked the wheels and spun each one in turn to see if I could hear grinding bearings. They all seem ok to me, not that I'm a mechanic or anything. There was no grinding though. I also tested moving both front wheels forward and backwards. On the drivers side there seemed little or no play at all but on the passenger side there does seem to be quite a lot more play. I have no experience to know if this is acceptable or not though.
Another symptom is a judder at certain speeds and I know that it isn't balancing as I had two new tyres just a week ago and had them all balanced. At high speed the judder is quite bad (70+).
From my unexperienced perspective I think it might be the drive shaft. Could anyone else shed and light on this for me?
Thankyou.
Golf GT 170 2008 70K miles
Thankyou.
