2footbraker
I've had this problem over about 2 years and it seems to be getting progressively more common.
At highway cruising, I normally boost around 5 psi. The problem is that my boost will go up to 10 psi for no apparent reason. Usually it goes up on gentle downhills but now it also does it on flat ground. Usually it drops back to 5 psi on gentle uphills.
Logs reveal that during these episodes, the requested boost stays the same but the actual boost pops up, corresponding to the boost gauge. The vnt duty cycle goes up too. So there is some kind of controller issue I assume. Unplugging the ASV changed nothing. Unplugging the EGR or the vane position sensor actually make the spikes worse, going up to 15 psi.
There don't seem to be any damaged wires or vacuum tubes. Another member had virtually the same problem and it turned out to be frayed vane position sensor wires but mine look fine form what I can see.
My egr duty cycle seems to be stuck at 100.6% most of the time. Could the vane position sensor be bad? What does this control exactly? Is there any way to test it? Do you need to get a whole new vacuum actuator assembly?
Any help would be appreciated. I think I am decreasing the life of the turbo when running it at 10 psi for long periods when it should be at 5 psi.
