Same here. Love to see picture of the map sensor location.
I can't get the photo uploaded to work for the last few days, no error, says file is uploaded, but don't show up, using phone, I get an error. . Anyway, got timing belt done, no more coolant leak. Got brake relays installed, no more dropping back to idle. Got new problem now, sort of, it did this on last drive, thought it was just the limp mode from loose boost piping. Went for a drive, ran good for 10 mins, then shutoff. Code p0321. Intermittent speed sensor fault. I could clear fault, and start, and drive and it would do it again. Does not do it at idle, and only seems to do it when warmed up. Did get boost up to 19lbs with no error so far, felt decent.
