I believe Sachs makes strut and shock mounts for VW (although there may be other makers, too). We carry those mounts only, and control arm bushings from CRP (Meistersatz) and Lemforder, also OE suppliers. Figuring out what is original equipment is a bit byzantine, as you need to consider manufacturer, who packages the products for the aftermarket, and manufacturing location. To get exactly the same product as came on your car would be a challenge.
I've had good luck with Sachs mounts on my wagon, although I'm a bit of a suspension slut so they get changed often. The ones that are in there now are coming up on two years (about 35-40K) and I'll probably replace them this spring and have the car aligned, although I don't have any symptoms of wear yet.
