Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
View Poll Results: If you have experienced intercooler icing, select from the following options...
I have experienced a hard start / no start / power loss with my original intercooler 111 88.10%
I have experienced a hard start / no start / power loss with the UPDATED intercooler 15 11.90%
Voters: 126. You may not vote on this poll
Old February 16th, 2016, 19:23   #256
Blackbug1
TDI(s): 2012 Jetta
Default Nashville intercooler icing
I am just curious if I am the only person from around the Nashville Tn. area that has had a major problem with intercooler icing? If you have had problems with it, did VW pay to fix the problem and did the fix work?
Thanks for the replies
Blackbug1 is offline   Reply With Quote
Old April 10th, 2016, 04:50   #257
RedBug
If you are still under warrantee then the dealer, if they can verify the issue, will install the kit. (If the dealer is worth a hill of beans that is...)
If your are out of warrantee, unless you have been complaining to the dealer and have records, they will want to charge you for the kit. You may have to go directly to VW in that case.
The kit reduces the problem but does not fix it completely. I just had my car do it again. Was able to get it started by being patient...
Condition: Sat for a few days after coming home in the rain. Temp going above and below freezing. Sweet spot for this seems to be < 45 Deg and wet combined with sitting for a period of time (to allow condensation I would assume). I have the latest kit....
Can't figure out how to change my vote in the poll as the problem took a long time before it showed up again....
Mercedes has a shutoff for the egr if the temp is below 50. My guess is that that is the correct fix as it is a moisture issue...
RedBug is offline   Reply With Quote
Old January 10th, 2017, 13:32   #258
GTSLOW
GTSLOW's Avatar
So has anyone bent a rod or caused damage from the hydrolocking? Mine started today and immediately died. I immediately pulled the lower IC pipe and sure enough. I doubt a rod or anything bent but I'm weighing my odds.
Sent from my Pixel XL using Tapatalk
2018 Camaro SS 1LE
2018 GMC Acadia
2012 Jetta "Premium" M6 - winter beater :P
Sold TDIs: '15 Passat/'11 Jetta (buy backs), '15 Sportwagen, '04 Golf, & '96 Passat.
GTSLOW is offline   Reply With Quote
Old January 10th, 2017, 14:12   #259
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Added my vote to the poll. My wife's car died in traffic before Christmas. From her discription, I think it is the IC. It sat for most of te three weeks since then, so I've not done anything to it. I guess I'll run it up on the ramps over the weekend and drill through the lower hose.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old January 10th, 2017, 14:25   #260
GTSLOW
GTSLOW's Avatar
What's your plan for dealing with the potential hydrolock?
2018 Camaro SS 1LE
2018 GMC Acadia
Old January 11th, 2017, 07:06   #261
kjclow
I'm draining the line, or at least taking it apart, this weekend. I noticed last night on the way home from the Y that the check engine light popped on and the engine started running a little rougher. The Golf will probably remain in the garage until the end of Feb when I have the buyback scheduled. My wife will take over driving the JSW.
Old January 11th, 2017, 14:25   #262
GTSLOW
GTSLOW's Avatar
Mines good to go. Pulled the plugs cranked the water out reinstalled everything and she runs great. 30mins tops.
2018 Camaro SS 1LE
2018 GMC Acadia
Old January 12th, 2017, 07:15   #263
bennybmn
Default Did I experience it??
Earlier this week it was below freezing for a couple days. Tuesday it was 17 in the morning and got up into the 30s during the day. I went to start it to go home, and it stumbled terribly and didn't start. Twice. I sat for a minute, tried one more time, and it worked. Is that what everyone is experiencing? All these years and I'd never had a problem...
Side note, can someone point me to a page of the thread with drilling instructions/explanation?
____________________________________________
Euro Switch, Dual horns and powder coated Portos so far... TC off switch soon!
bennybmn is offline   Reply With Quote
Old January 19th, 2017, 07:07   #264
bennybmn
I guess folks aren't checking this thread much anymore
Old January 19th, 2017, 07:56   #265
kjclow
Because the drill fix wasn't in this thread: http://forums.tdiclub.com/showthread.php?t=431560
Old January 20th, 2017, 07:05   #266
bennybmn
Thanks for the link!
Can you confirm the water thing is what I experienced from my description?
Old January 20th, 2017, 12:34   #267
kjclow
It sounds like what everyone else has mentioned but I wasn't in the car when my wife had issues. I've not had any problems with my JSW. I'm guessing that even though I have a short commute (7 miles), I don't have much stop and go traffic. I can keep her at 45-50 for most of that short trip.
Old September 16th, 2017, 11:04   #268
CrazyDazed
TDI(s): 2013 Jetta
If any of you are having issues getting this replaced, long story short, I opened a case with the BBB against VW Canada. Then VW Canada then paid for the Winter Intercooler Kit for free, no questions asked. Which made sense it was common sense that it should have been replaced from free in the beginning.
Longer story was that I opened a case with Customer Service. This went on for almost a year as Customer Service was extremely frustrating to deal with. Customer Service would do things like tell me they could only escalate to a supervisor and then later admitted they could escalate higher. And told me they did so. However, when I did not hear back, like many things Customer Service said they were going to do, they had not escalated the issue. They also said that the dealership told them that my issue was not with the intercooler, even though the dealership told me it was. The dealership was so mad, they even cc'd me on an email to VW Canada stating it was the intercooler. Note that this was the second dealership to say I had issues with the intercooler. This issue was so frustrating and so disappointing that this is the last VW I will ever buy.
CrazyDazed is offline   Reply With Quote
Old January 7th, 2018, 09:57   #269
CRWalker
Fuel Economy: 42mpg avg.
Default More Info from Experience
Hey all, I thought I would share what Iíve learned through this issue. I had a P0401 code awhile back and stumbled onto this Intercooler tsb. Thinking this might help cut down on Intercooler sludge and help the engine run more efficiently would thus cut the sloppy egr. Anyway, I purchased and installed on my vehicle (which happens to have the CBEA engine, pretty similar to CJAA for those that donít know.) I was still getting the brown junk in the Intercooler cold side pipe. Due to a leaking valve cover gasket and wanting to replace the pcv which is the valve cover itself, I ended up fixing most of the sludging! Turns out the particle separator system had clogged at some point and was allowing oily pcv gasses to dump into the intake and turbo and straight into the Intercooler. Now I just need to replace the glow plugs and Jenny shouldnít any more problems starting even in the current single digit weather.
Hopefully this helps someone who is as frustrated as I was.
CRWalker
CRWalker is offline   Reply With Quote
Hard Start / No Start - Is your intercooler frozen? Check Here! GraniteRooster VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5371 Today 18:20
Golf tdi 99 hard start from cold and yesterday won't start at all deep_sing VW MKIV-A4 TDIs (VE and PD) 17 December 13th, 2013 07:48
Hard start problem, still after going every hard start thread snowboardphil VW MKIV-A4 TDIs (VE and PD) 9 July 6th, 2013 18:31
98 Jetta tdi Hard to start hot, now no start DRVRFWND VW MKIII-A3/B4 TDIs 6 February 7th, 2011 23:01
Discussion: 01 Jetta no start paramedick VW MKIV-A4 TDIs (VE and PD) 11 June 30th, 2008 15:24
Page generated in 0.17855 seconds with 11 queries
[Output: 123.58 Kb. compressed to 103.59 Kb. by saving 19.99 Kb. (16.17%)]
