Str9012 said:
The other day at the auto store i came across some Valvoline Engine Flush, said that it would clean the junk out while running it in with the oil about 5 min before changing to oil. Anyone know if this really does anything beneficial i have a 2001 jetta tdi with 140,000 miles on it and have just been thinking lately about things i might need to start thinking about to ensure my engine runs long and hard for many miles to come.
If you've been running synthetic diesel oil that at least meets 505.00 or CF-4/CI-4/CI-4+, for normal drain intervals for your car (10K/1 year stock, maybe shorter if modded), than you shouldn't have any significant crud to clean.
Here's an example of what happens fairly regularly with petroleum oil - especially lower quality petroleum oil. In this example, it's comparing an API SL/ILSAC GF-3 petroleum to an old non-detergent API SA petroleum oil. But I've seen the same level of crud in 1.8T engines running modern petroleum oil.
It will take more than a 5 or 10 minute flush to clean this, however.
Oil has detergents and dispersants to control contaminants. Petroleum oil can leave more deposits and contaminants than the oil can control. Continuous use of 3000 mile oil in an already dirty engine can make things worse over time, because the additives in the new oil are quickly depleted trying to clean up the mess - and there's nothing left to handle the deposits created during that drain interval.
This is the main reason for the early engine flushes - like AMSOIL's product - that goes back to the early 70s. Nobody used synthetic back then, oil quality was lower, there were a lot of dirty engines. There's wear metal and other abrasives trapped in the crud. Installing a long-drain synthetic in a dirty engine can liberate the abrasives and cause increased wear and seal damage.
Here's an image from an engine that I will use at least one round of an engine flush on. I'm working on a friend's Dodge minivan with a bad head gasket. The oil is full of water. There hasn't been any coolant in the system for awhile, so this isn't a glycol issue. Here's the oil fill cap:
Chances are, your engine looks more like
this engine that had 225,000 miles of synthetic use. If that's the case, you can skip the flush - your engine's clean.
