Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > TDI Cars for Sale/Wanted
TDI Cars for Sale/Wanted VW TDI/Diesel cars for sale and wanted.
Old September 12th, 2018, 14:57   #1
i am sam
TDI(s): 2006 Jetta
Default FS in Minneapolis: 2006 Jetta TDI 5-speed, 165k, no rust, all common probs fixed, $6k
I moved here last year from Colorado, and I believe I am effectively the second owner of this car (first owner traded it in, then it transferred dealerships, then I bought it with 85,000 miles on it). This car has been in Colorado all its life until June 2017 when I moved here. It has only been in one MN winter (last winter), and I kept it in heated underground parking in my apartment, and sprayed it off regularly.
I have performed very extensive maintenance and some modifications. The car needs nothing, and will probably need nothing for a very very long time (besides timing belts every 100k miles). I drive it to Colorado and Wyoming and back once a month (2600 miles round trip), and when I lived in CO, I drove it ~800 miles every weekend to Sheridan, WY and back. I average about 40-42 mpg every fill-up.
Maintenance performed:
- At around 100k miles I upgraded the faulty dual mass flywheel (which was failing) with an upgraded single mass flywheel and new clutch. This will last the rest of your life if you drive right.
- At 117k miles I upgraded the camshaft and lifters with a Colt Stage 2 camshaft and Colt nitride hardened lifters. I also put a head from a Passat on the engine with all new gaskets and seals, and larger Passat injectors. The camshaft comes with a 300,000 mile warranty, and will also last the rest of your life. I also replaced the timing belt, tensioner, and water pump. The parts alone for this cost $2000 (the cam was $700).
- Regular oil changes every 10k miles with LubroMoly synthetic oil from Germany that meets the stringent VW spec (I order it from Ebay).
Upgrades:
- KermaTDI tune to increase boost, and take full advantage of the larger injectors and Colt camshaft. Tune upload tool is included with the car, where you can pick one of five tunes, or return the tune to stock.
- 2.5" stainless catless turbo-back exhaust (original cat converter system is included with the car)
- Removed EGR system and ASV system (the tune programmed them out as well, so no check engine light). With no EGR system, you get better power and fuel economy, and no carbon clogging of the intake.
- Heavy duty coolant circulation heater. This is a MUST in MN winters. The heater is 1000W and thermostatically controlled to 190 deg F. If you plug this in for three hours, it heats the engine coolant to operating temperature when it is -20 outside. Worth every last penny.
- Full engine/trans skidplate/protector made of 3/8" aluminum
- Koni STR.T shocks
- Tein springs
- Audi TT front control arm bushings
- Powerflex engine dogbone bushing
- 18x8.5 Audi A8 wheels (stock steel wheels and tires are also included)
Things to know:
- Because of the tune and injectors, if you step on it, you will produce some black smoke from the tailpipe, which is just the way diesel is.
- I only have one key, and the fob doesn't work. I bought a new fob, but it needs to be programmed either at the dealer or by someone with the VAG-COM tool (which I don't have).
- The title is currently held by the lienholder, Navy Federal, so when someone buys the car I can have Navy Federal release the lien and send the title to the new owner.
If you are interested, I work in Eden Prairie most of the day, and I am available at almost any time to step out of the office and show the car. I live in Rockford, but I usually don't get home until late evening.
i am sam is offline   Reply With Quote
Old September 12th, 2018, 19:46   #2
Tsch125
Nice car! How many miles are on it now?
Tsch125 is offline   Reply With Quote
Old September 17th, 2018, 08:50   #3
i am sam
TDI(s): 2006 Jetta
Sorry for late response, I added the miles to the title, 165k.
Old September 19th, 2018, 07:20   #4
Stromaluski
Stromaluski's Avatar
I don't normally like silver cars or mk5s, but the ride height and wheels on that car are just right. It looks awesome. GLWS!
-Andrew
Stromaluski is offline   Reply With Quote
Old October 9th, 2018, 14:21   #5
i am sam
TDI(s): 2006 Jetta
bumpnado!
Prob the wrong time of year to be selling a lowered diesel car in Minneapolis...
Old October 10th, 2018, 09:28   #6
tydaddy
tydaddy's Avatar
Pm sent
PT, DPT, MS, ATC, CSCS, PES
2003 Jetta TDI Wagon - sold
2010 JSW - Malone Stage 2, DPF, EGR, ASV deletes. Nicktane. 2microntech. Etc. - sold
2005 TDI Wagon, Malone 1.5, 2010 Touareg V6 TDI
Hex-Can USB owner
tydaddy is offline   Reply With Quote
2006 Jetta TDI Pkg 1 - Minneapolis, MN - $12,750 paix247 TDI Cars for Sale/Wanted 7 October 4th, 2015 12:25
2006 Jetta TDI, auto, pkg 1, 55k mi Minneapolis, MN paix247 TDI Cars for Sale/Wanted 1 October 5th, 2014 08:54
FS: '04 Jetta TDI GLS, Minneapolis, MN Goodie TDI Cars for Sale/Wanted 0 August 5th, 2013 20:35
FS: 2006 TDI Golf GLS, Minneapolis, MN (Low miles) BriTdi TDI Cars for Sale/Wanted 11 February 11th, 2011 08:28
2006 VW GOLF TDI Excellent Condition Minneapolis MN matt_1997 TDI Cars for Sale/Wanted 4 August 14th, 2010 01:05
Page generated in 0.12562 seconds with 12 queries
[Output: 80.08 Kb. compressed to 70.79 Kb. by saving 9.29 Kb. (11.60%)]
