G gbpakrz Member Joined May 14, 2013 Location Reno, nv TDI 2002 Jetta TDI Jun 13, 2016 #1 HOT INTERIOR .. Vacuum leak?? Or what?? Can't stand the heat.
P PGM jetta Veteran Member Joined Dec 14, 2015 Location Northern Alabama TDI 05 Jetta BEW Jun 13, 2016 #2 Would you elaborate please? Is the a/c functioning properly? Has the car been spitting foam out? Sent from my XT1254 using Tapatalk
J johnboy00 Veteran Member Joined Jun 15, 2000 Location Bridgewater,Ma.,USA TDI 2005 Passat Wagon, 2004 Jetta, 2003 Jetta wagon Jun 13, 2016 #3 There are a couple of threads in the A4 section. Do a search, if this doesn't help you: http://forums.tdiclub.com/showthread.php?t=222830&highlight=Blend+door
