rt_hawk
I couldn't find much for install instructions for a BRM with the DSG...so here are some pics of what I did...I was worried about having the trans cooler in line but it's working great...hardest part was getting the stupid line attached to the oil cooler...
I installed the cooler behind the lower drivers side grill insert...I used split loom over everything to avoid any rubbing issues...although the only spot that was a concern is where the gates 5/8" hose runs behind the lower intercooler bracket and then to the oil cooler...I used a 90* 5/8" gates hose for the top off the zerostart and then a plastic 90* bend to connect to the stock hose entering the dsg cooler. I used OEM style rotor clip Corbin style clamps on everything...I hate worm gear drive hose clamps...anyway just thought I would share...I made my own kit...probably the same cost as the frost heater kit...but I only had a afternoon to do this and couldn't wait...
