I completely missed anything you might have mentioned regarding your mods, particularly the pistons and what you have done to reduce the compression ratio. I just read yesterday that your compression test came in at only 360 PSI.
I try to keep all that info in the op. MrChill would be the one to ask about exactly what was done to the pistons, and he has not been able to provde me with much info up till now. As previously posted I have a PD150 block/crank and modified ceramic coated pistons. As I recall, what ever was done to lower the compression on the pistons was not dramatic, as they did not look much different than the stock pistons I had to compare them too at the time.
As far as the compression goes. I've had it checked twice with substantially different results 360 vs 425. So the jury is still out on that count.
Based on that, I estimate that your end of compression temperature is getting at best up to about 450 degrees Celsius.
What are you saying here?
Unfortunately without this sorted out, IMHO I predict that a cam comparo is not going to give very promising or flattering results to any non-stock cam...
My car will not be used to test your cam today. Chill is using his car as the test mule.
I had to develop a very complicated spreadsheet together with TDIsyncro to calculate this, as shown below.
Interesting, but I cant see the data on my screen and am not sure how it applies here.
Too bad about the deer. I'm surprized the police stopped you. We'll be doing this again next year in preparation for the Maxton Mile, if they ever post a schedule so I can get things put together.
