ejallison1
- Joined
- Apr 28, 2010
- Location
- Kansas, Illinois
- TDI
- 98 Jetta TDI AHU, 97 Passat TDI AAZ, 04 Golf TDI PD, 01 NB TDI ALH
1997 B4 sedan, 375,000 miles, old new car to me with the usual rust. Brakes will act like I have a line leak when the temp dips to the mid 20's F. Brake pedal goes to the floor and minimal braking action, no problem with clutch pedal. When ambient temp get's back in the 30's F brakes function returns to normal. There is no appreciable loss of brake fluid.
First time this happened initially thought a brake line ruptured due to water in the braking system. Inspection revealed a very small drip on the rt rear brake caliber but brake fluid level was OK. Went ahead and thoroughly bleed all 4 corners and the clutch-pretty nasty looking old brake fluid. Everything seemed fine till the temps dropped again and then the same thing happened.
Would a fine hairline crack in the brake caliper expand in cold weather and cause this? Have not seen any more brake fluid on that rt rear caliper or any loss of brake fluid in the reservoir since bleeding the brakes. Any ideas on what the problem could be?
