KyleB
I've got what I think is a weird one for you.
I've had my 09 Jetta TDI for a few months now. It took me a bit to figure this one out. I mean, how often do you look at your car with the lights off then on? The daytime running lights and the low beam lights have been switched. That is to say, any time the ignition is on, my low beams are on, and when I turn on my lights with the switch, the DRLs turn on. All the other lights seem to work with the switch as you'd expect.
Is this a possible mod with VCDS?. Is there an easy way to swap a couple wires to achieve this effect?. It's this likely an error someone made in the past, or has anyone heard of doing this on purpose?
Ultimately, I'd like to undo it. But that means figuring out how it was most likely done in the first place. Thought I'd start by picking your brains.
