Started the last part of the Jetta's crash repairs. The lights. I crammed a set of mini D2S projectors into a set of e-code buckets, and discovered that the reflector shape led to alignment issues. The upper half of the reflector curves towards horizontal much faster than the lower, so the projectors pointed too far downwards. This is getting solved in two ways, first some reflector material removal with a rotary file is in store, the second is an adjustable support under the solenoid. The first will be set on the bench, and with re-assembled buckets aligned on the car. Then the covers shall be re-installed. Running D2H bulbs and Hylux A0050 ballasts on a Morimoto H4 harness. Signal to the harness is taken out through the larger cover to an H4 socket. HV for the bulbs, and high beam signal to the shutter is passed through the silicone grommet supplied with the bulb, and it is right behind the bulb. Hook up the stock connector, plug in the AMP connectors to the bulb, the harness signal input to the H4 socket and connect the 9006 shutter connectors on the DS; the passenger side just gets just the HV and shutter connections plus the stock connector.
cheers,
Douglas
