tadawson
Hey, quick question for the mileage crowd . . . on the 2013 Passat, might anyone know either the total fuel tank capacity, when filled to the neck, *or* how much is typically left when the range reports zero? Not planning to push that hard, but finally did a cross country alone (my wife is a mash and release driver . . . drops 10mpg thr second she gets behind the wheel) from Dallas to Ames, Iowa, straight up I35, Speed from 72 to 77 typically, AC running full (high 90's to 100 degrees most of the way), and pretty loaded. Hit low fuel at 730 miles, and completed the leg at 757.2, showing 50 miles more on range, giving about an 805 mile tank. (And too 17.19 to refill). As noted prior, in case I get caught, wondering what might be left. Oh, and that's 44.05 mpg calculated, and 45 as reported in the MFD . . . was hoping for better, but can't complain,considering.
This also illustrates why I have *ZERO* inteest in an e-turd as they stand today. Total stop time was 21 minutes, 6 or so of which should not have happened . . .
- Tim
- Tim
