Sorry to start up another fog light thread, but I've got a question about OEM lights and I can't find specifics for this car.
I'd like to do the OEM install if possible, but I believe I have midline control module in the car. Part number: 5K0 937 084 G.
I've tried to enable fog lights in VCDS, and I did get two bulb out indicator warnings. The fact that this works suggests that I have a highline module, which is confusing. I'd like to make sure before I start buying parts.
I'm willing to take the kick panel off and poke around the plugs to determine if the pins are present, but I've been unable to find a pinout for the control module. Which plug would the fog lights connect to, and which pins would need to be present?
The reason for the OEM install is to get the low speed fog illumination assist when turning. I drive though a foggy area pretty regularly as well so I'd be ok with the ECS kit version, but I figure the turning lights would be handy.
