Old January 19th, 2009, 13:24   #1
DM344
TDI(s): BEETLE TDI
Default Car runs fine until you cut it off- Will not crank
I need help. I have read many fine post from knowledgeable contributors .
VW 2002 new Beetle ALH engine. Using B90 and runs fine until you turn it off.
It will not start,have been towed home for a second time.
I have replaced relay 109,checked for "on" position of the anti shudder valve,
the glow plug light comes on and then off.
I then tried to put a vacuum at the incoming hose at the fuel filter and do not get any fuel.
I am now back at the fuel pump on top of tank to try to see if it is stopped up.
I cannot understand How to remove the 2 hoses and the electrical socket on top of the fuel pump.
Please provide detailed directions to do this.
Also any ideas of possible problem??
Thanks in advance.
DM344
Correction: Car will not start.Battery and starter working fine.Also has a new fuel filter.
The first time this happened,towed to a mechanic and cost $350.00. He said he removed the fuel pump,cleaned the filter,removed the B90,replaced with regular diesel fuel, vacuumed the air from the fuel lines,
Car ran about 3 weeks and same thing happened.
I need instructions on removing hoses and connector from top of fuel pump.
thanks
DM344 is offline   Reply With Quote
Old January 19th, 2009, 14:51   #2
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
It appears this has happened more than once. What got it working again previously?
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old January 19th, 2009, 15:44   #3
Naimanator
Naimanator's Avatar
You say it "runs fine until you turn it off". Are you saying that it will start and run in the morning or whenever the engine is cold, but then once it has been driven and the engine is hot it won't crank over? If you can clarify this for us, the conditions under which it will and won't start, then it will be easier for us to help you.
2002 Golf GLS TDI 5-SPD~101k miles (Silver)
Mods:
RC2, Koni FSD's,
OMI, EGR Delete, 5 Brake Light Mod, DRL's Gone, Evolution Atlas Skid Plate, Coolant Migration Mod, Ventectomy.
"The Enrichment Center is required to remind you that you will be baked, and then there will be cake."
Naimanator is offline   Reply With Quote
Old January 19th, 2009, 15:52   #4
ninedee_golf_tdi
You don't need fuel to crank the engine. Your problem is elsewhere.
ninedee_golf_tdi is offline   Reply With Quote
Old January 19th, 2009, 15:54   #5
Naimanator
Naimanator's Avatar
If the problem is that it just won't crank when the engine is hot, it sounds like your starter motor is getting weak and needs to be replaced.
Mods:
RC2, Koni FSD's,
Old January 19th, 2009, 15:59   #6
Lefty
Lefty's Avatar
Fuel Economy: 48.5 MPG
Have you changed the fuel filter on time? Running BIO and running on an older filter can cause no start. Bad battery can cause it also. Or even bad ground connections.
<===Lefty===
2000 GLS Jetta TDI 48.5 MPG 370k and Counting
Lefty is offline   Reply With Quote
Page generated in 0.11748 seconds with 10 queries
[Output: 70.23 Kb. compressed to 60.78 Kb. by saving 9.45 Kb. (13.46%)]
