LKN
Who here has the highway mileage bhw, with an original engine?
There's examples of PD engines that are not BHW engines reaching over 500k miles without a rebuild, and I've heard of a few BHW engines over 300, and one over 400. The BHW's bottom end is much stronger than most other PD engines, at least once the BSM is taken care of. It should be capable of going much further than 500k. The problem is that most people stop caring for these cars(outside of a few enthusiasts) when the BSM needs to be replaced or high dollar service items are needed for these old cars.
That was taken six years ago. Not sure of the whereabouts of that car now, but I did see it again after it crossed 400k. That is 378k in the pic. It had just had its original transmission replaced. I did its balance shaft upgrade a couple hundred thousand before that. Engine original otherwise.
Really any car can be made to last pretty much indefinitely, although some age better than others. My 220k mile Passat despite also being 13 years old, feels tighter and better inside than this horrible piece of junk Chevy Captiva that I just had to replace the cam phase solenoids on. God what a miserable piece of crap.
67,100 miles. One of 4 vehicles I own, driven most days.
Need tips on making it last. I plan to keep it indefinitely. I have always changed oil at 1 year intervals, usually around 5k miles.
Good to hear, You sound pretty well informed. There is a thick ground wire to the starter that can rub against the boost hose. This is the hose connecting the turbo to the inter-cooler piping at the bottom of the radiator. Its on the passenger side. Its definitely worth checking (easiest to see from underneath) to make sure there is clearance. The wire held on by a tie wrap and will eat through the boost hose it not in the correct place.Did a timing belt and balance shaft delete, new motor mounts last January at 61,500 miles. Also changed transmission fluid and filter at that time. Zahntech in Redmond WA did the work, no complaints. Looking to avoid the turbo/boost issues that keep cropping up on this forum. I have plenty of short trips in town but wind it out on the highway at least once per week.
By the way, after the BS delete vibration is minimal and car runs like new. Fuel economy was not affected. I went to Michelin Defender tires and lost 1 mpg from previous Continental Conti pro contact.
