Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old October 9th, 2016, 11:01   #586
Andy_2009_JSW
Member Name: Andy_2009_JSW
Model Year: 2009
Model: Jetta Sportwagen
Tranny: DSG
Miles: 166500
Oil Ash Volume: 210 ml
Oil Type: Mobil-1 ESP 5w30
Avg MPG 35-ish
State: GA
Additional VCDS (version 16.8.2) data points:
4.2g Soot (calc)
0.0g Soot (meas)
1 Requested Regens
2.4l Fuel consumption since last regen
30km distance since last regen
48 time since last regen (minutes)
Remarks:
My P0401 (EGR insufficient flow) code/check-engine light has now been on constantly for probably the last 30K miles/18 months. Soot at tail pipe. Pretty certain DPF is cracked.
Back in late spring or so I had a month+ where car was doing extended 30+ minute regens multiple times per week (~250 miles avg weekly commute) -- this was quite concerning given dieselgate fiasco/uncertainty. I do NOT know if this is related, but I fixed a P2015 error code with the Diesel Geek motor stop insert early in the summer. For many months now regens have thankfully been much more normal; no more worryingly long ones, nor excessively frequent.
Any speculation if or how these could be related?
Andy
SOLD BACK: 2009 JSW TDi (09/08), Salsa Red, 17" Gray Goals, DSG, Curt trailer hitch, Dieselgeek Panzer plate, Aspherical mirrors, H&R RSB, warrantied mechatronic replacement (02/12), unwarrantied turbo failure (at 80K mi, 06/12), radiator replaced @115K mi (03/14) and AGAIN @163K (08/16), rear towing springs (03/15), ~176k miles so far
Andy_2009_JSW is offline   Reply With Quote
Old October 9th, 2016, 11:05   #587
Andy_2009_JSW
Originally Posted by jason_ View Post
270K miles on an '09. Ecm showing 379mL.... !
Wonder if that's accurate? Mostly because it's cracked. But then I've been dumping so much optilube it's almost pointless to stop for diesel....
And we now have an official winner, folks!
Andy
Old April 15th, 2017, 13:56   #588
drettele
Fuel Economy: awesome
MemberName: drettele
Model Year: 2009
Model: Jetta
Tranny: DSG
Miles: 205,000
Oil Ash Volume: 219ml
Oil Type: Mobil 1 European Car Formula Advanced Full Synthetic 0W-40
Avg. MPG: 43
Comments: Just recently started getting P0401, P20D8, and P2413
Sent from my SAMSUNG-SM-G935A using Tapatalk
drettele is offline   Reply With Quote
Old April 24th, 2017, 06:59   #589
jason_
Towards the end ash level stopped increasing, and I was dumping in 16oz of super tech 2 stroke on every tank, and it would still always show zero for measured soot.
That thing was so ridiculously cracked. Such fragile components....
Sent from my One using Tapatalk
jason_ is offline   Reply With Quote
Old June 4th, 2017, 10:55   #590
mirage2521
Originally Posted by Absolute Diesel View Post
This is a very big concern IMO. I think it's safe to say that eventually, the DPF will become clogged and need to be replaced, whether that's at 100K or 250K. If they cannot be cleaned as I was hoping, VW better find a way to bring the price of replacing these down to a few hundred rather than thousands. Otherwise I see DPF deletes in many people's future or dumping their CR VW (which is a shame b/c this car is awesome) for possibly Mazda Sky-D.
305,000 miles, zero regens, zero problems.
Diesels past and present 2015 Passat TDI SEL, 2013 JSW TDI, 2010 Jetta TDI, MB 300D
2003 Ford F250 6.0l Power Stroke
mirage2521 is offline   Reply With Quote
Old March 6th, 2018, 21:12   #591
sdeabs
MemberName: sdeabs
Model Year: 2010
Model: Jetta MK V TDI 2.0 CJAA
Tranny: DSG
Miles:154K
Oil Ash Volume: 150ml
Oil Type: Liqui Moly TopTec 4200 but switching to Mobil 1 ESP in future
Avrg. MPG: 41
Comments: Recalls have been completed. Getting P0401-001, P0401-002, P240F-000, & P0002-007. Have initiated emergency regeneration three times recently and cleared codes. Soot load has been as high as 20.7 and as low as 1.2. Most recently 8.7.
Scot
2006 Jetta MKV TDI - 5 speed manual - 289K total loss 08/20/2013
2010 Jetta MKV TDI - 6 speed DSG
sdeabs is offline   Reply With Quote
Old May 4th, 2018, 12:41   #592
jason_
Model Year:
2015
Model:
S wagon
Tranny:
Dsg 6sp
Miles:
21, 898
Oil Ash Volume:
7.8 mL
Oil Type:
Dealer supplied oem
Avrg. MPG:
Low 50s.
Sent from my 2PS64 using Tapatalk
Old June 2nd, 2018, 05:19   #593
mjhandy
mjhandy's Avatar
Why am I just find this thread now. I had the DPF cleaned back in November, but i drive maybe 15 min at a time now, so it was only a matter of time before i started to get the warnings.
So a forced regen yesterday, then two long hour + drives at high way speeds. I haven't checked numbers this morning. Coffee first.
Mark J. Handy
HEX + CAN usb
2009 Touareg TDI
2000 Jetta TDI, 568K km, Bye bye
mjhandy is offline   Reply With Quote
Old September 26th, 2018, 13:23   #594
hajes
wouldn't be better to collect info about pressure difference as measure for clean DPF?
I recently swapped DPF nor a new one...old one had pressure restriction 200mbar...turbo must have pumped more hard...normal pressure difference suppose to be 30mbar
Furthermore, DPF older than 4 years has no more precious metals to react with...it is simply just soot collector and dead cat.
My 12 years old DPF had 0% of palladium or platinum.
hajes is offline   Reply With Quote
Old September 26th, 2018, 16:09   #595
mjhandy
mjhandy's Avatar
There are no precious metals in a DPF, it's a block off filter.
Mark J. Handy
HEX + CAN usb
2009 Touareg TDI
Old October 5th, 2018, 15:57   #596
hajes
catalytic convertor + DPF in VW...both things together, which means precious metals for oxidation ;-)
Old December 3rd, 2018, 08:13   #597
fairbanks
Default Emissions Workshop
My car is a 2005 Passat, 2.0 TDI
I have become very intimate with her, I have stripped her down several times, and when I'm done she still responds the same way, Emissions workshop!
I have replaced the fuel\vacuum pump
Turbo, the mass air flap,the inter cooler hose from turbo, the silver domed vacuum reservoir, all vacuum lines, the cylinder head, I have cleaner the air sensor just before the engine, and changed the oil, and even gave her a kiss.
How do I clear this Emissions workshop?
The head was the problem, two valve failures, with the new head it starts up right away, not even one turn, I have the OBDeleven, that can clear codes but how can I clear the Emissions Workshop?
fairbanks is offline   Reply With Quote
Old January 7th, 2019, 16:27   #598
bigb
Hoping the participants of this very informative thread are still around, and with the number of buyback cars now finding new owners maybe this thread will become more active again. I bought my TDI two weeks ago and have been studying the emissions system with great interest this being my first SCR diesel. Here is my big question: When I bought the car from a wholesaler they had the oil changed at a quick lube place. I drove it almost 1,000 highway miles before I realized the oil they used was Valvoline 5w40 Blue Full Synthetic. I went to a VW dealer and had it replaced with VW 507 spec oil as soon as I realized it. Do you think there will be any long term effects from the 1K miles without the low ash oil? The car presently has 28K miles on it.
bigb is offline   Reply With Quote
Old January 7th, 2019, 16:37   #599
Lightflyer1
Lightflyer1's Avatar
In a word, no. Just drive on and keep the correct oil in it now for the future. Nothing more you could do at this point anyway.
Old January 7th, 2019, 17:03   #600
bigb
Thanks Lightflyer1.....I suspected it wouldn't be a big deal. One more question.....is the EGT-2 and EGT-3 sensor info from the OBDII the same as catalyst temp and DPF temp?......(I noticed that's where these two sensors are located)....thanks....
Long-term DPF data project DoctorDawg VW MKV-A5 Golf/Jettas 55 January 30th, 2013 16:42
Off-topic posts from Cam Failure Data Collection thread donDavide Fuels & Lubricants 63 June 14th, 2011 23:18
PD cam failure - Data collection thread SBAtdijetta Fuels & Lubricants 116 February 25th, 2011 21:21
Biodiesel in DPF/Clean diesel vehicles Drivbiwire Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 6 August 25th, 2010 08:55
2009 Jetta Clean Diesel w DPF = Regen? Rod Bearing TDI (Diesel) Emissions 5 October 15th, 2008 18:58
Page generated in 0.19555 seconds with 13 queries
[Output: 129.66 Kb. compressed to 108.93 Kb. by saving 20.73 Kb. (15.99%)]
